Trail cameras are great for tracking game and giving you a leg up in your game hunting. But if the camera's aren't set up properly you will not be getting the images you want or be able to track the game you want. Here are just a few tips to be aware of when it comes to setting up your trail cameras.
It is recommended that you test your camera in the backyard to make sure that you are familiar with the equipment and its usage.
Once you have a grasp of how the system works you are ready to head out and set up. Start by setting up with camera between 10 and 15 feet from the target area at about waist height.
A few things to consider about where you set up the camera are the stout because you want to make sure that the tree wont move too much. Make sure that nothing is obstructing the camera's view because this may cause false triggers and obscure your image. If you can find somewhere that doesn't have a lot going on in the backdrop is the best, because too many limbs in the background can obscure the view of antlers.
When possible you should set up the cameras facing north to avoid getting sun glare. Stay away from areas that tend to get a lot of fog.
After the camera has been up for a few weeks you should have some good shots of the deer you are tracking and will have an idea for where your stand should go and when the deer are going to be there.
Check your controller settings in the menu. If you had previously changed it for the standard controller where the accelerate button was changed to the switch camera angle button it will do the same with pedals and driving wheel. Or their might be a setting to change controller to a driving wheel in settings. Most likely the first option.
basketball game is a fast moving object which is hard to take the picture perfectly sometimes
always using a flash, or external flash for more lighting support, set the shutter at about 1/80 or faster, ISO setting is 400 to avoid darker result, the Aperture should be set at the biggest number such as f 1,4
First of all, don't use the flash...it's only good for a short distance. Obviously, you need a fast shutter speed to stop the action. To get this to happen while in auto mode, you will need to set the ISO to a higher number such as 800 or 1600. You will need to take a couple of test shots to find the correct setting.
