First remove all lines from tank clean tank by spraying carb cleaner into it shake well make sure all gunk is out then blow out with compressed air. Install lines with no 5 going to fitting just below primer bulb the other line no. 3 has connector no 6 and filter no. 4 on it.
Using compressed air or spraying cleaner under pressure into carburetor ports may displace welch plugs requiring carburetor repair/replacement.
SOURCE: oil/gas ratio for a modle UTO8110 homelite leaf blower
you can run 32:1 if you want to it wont hurt it but it may foul a plug since its more oil, 50:1 is the best ratio for your blower
"top of the gas tank where the gas tube fits into the tank"
I assume you're describing the gas tank cap. if so, the o-ring is missing from the gas tank cap. You can find those at hardware stores.
SOURCE: How do I adjust needle valves on a 25cc Homelite
Set the lowend & highend needles to about 1 3/4 to 2 turns each. Choke the carb or prime it, until the carb is wet. Fire up the engine and let it warm up. Let's set the topend first since it's the easier of the two. Go to full throttle. Adjust the topend needle for peak RPM. Leave it wide open for about a minute to see if it changes any. Should the engine go lean, open the lowend needle slightly, if this dosen't work... you will have to adjust the needle valve inside the carb.( I will explain this later) If the topend runs OK, then slowly pull the throttle down until the engine begins to "four cycle" hold the throttle there. Adjust the lowend needle until the "four cycling" barely stops. Now lower the throttle more until it "four cycles" again, and adjust the lowend again. Keep doing this until you reach full idle. Now, from full idle begin to throttle up until the engine starts to bog or hesitate. Open up the lowend needle just enough to eliminate the bog or hesitation.
http://tech.flygsw.org/walbro_tuneup.htm
hope this helps :)
if it does please vote
SOURCE: My Homelite backpack leaf blower only idles. when
Is the new gas some you just mixed up from the gas station or is from the can in the garage? If it is indeed fresh then you are looking at needing the carburetor adjusted. Sorry you can not do it yourself, The epa only allows qualified technician to adjust them. Plus the tool to do so are not available to the general public.
HTH
Good Day.
SOURCE: bogs down at full thouldel tryed to adjust carberator
Hi
This is either a clogged muffler or carb. Take the off and see if it will rev. If not you need to clean carb and install a carb repair kit. Do not run long with muffler off.
Sam
