Apple iPod classic MP3 Player Logo
Nick Vassar Posted on Oct 26, 2016
Im trying to find out what gen ipod classic I have,here is the serial #: 8K4262M19ZS and it is 160 GB, THANK YOU!
5 Related Answers
Anonymous
  • 342 Answers
  • Posted on Jun 22, 2009
SOURCE: My iPod 160 GB Classic is stuck with just Apple
Try forcing the iPod into disc mode to restore.
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
If this does not make the iPod connect to your computer, I would suggest checking out www.rapidrepair.com for further ideas and options to your issue.
Anonymous
  • Posted on Aug 22, 2009
SOURCE: my ipod classic 20 gb
The wall adapter logo means the ipod need connecting to an external power scource to complete the restart procedure. Once this is done it will reset to the facory settings.
Anonymous
  • 863 Answers
  • Posted on Nov 05, 2009
SOURCE: restoring an ipod
Make sure you got the latest itunes version and latest ipod classic version.  Also you need to be on the original computer you used to sync with the ipod.  Open up itunes and connect the ipod.  Your ipod should show up on the computer.  Just click on the restore itunes back to factory default button and you should be g to g.
Anonymous
  • 14 Answers
  • Posted on Mar 14, 2010
SOURCE: 80 GB Ipod Classic shows locked and click wheel not working
Slide the switch on the top of the ipod to where it shows white instead of orange. If it is already off hold, then you may have a broken hold switch.
lunalife
  • 12 Answers
  • Posted on Nov 08, 2010
SOURCE: My ipod displays charging please wait..... and wouldn't charge???
google it. also another thing is to try is plug it in and hole menu and center button until an apple turns up or until yoour omputer reconizes it
Ipod classic 160 gb trying to find the serial number
It will be on the device details label, if it has one. Otherwise on the packaging it came in.
What gigabyte is my iPod
iPod touch (5th Gen, 16 GB, 2014) 1.0 GHz* Apple A5* Intro. June 26, 2014* Disc. July 15, 2015 Order MGG82LL/A* Model A1421 (EMC 2600*) Family 5th Gen ID iPod5,1 RAM 512 MB* VRAM None Storage 16 GB* Optical None Complete iPod touch (5th Gen, 16 GB, 2014) Specs
Data recovery..?
you could buy an ipod case cover or buy the ipod case itself if you are tech minded and can change all parts over to new casings
http://www.ebay.com.au/itm/Clear-Hard-Plastic-Case-Skin-Cover-Apple-iPod-Classic-80GB-120GB-160GB-Video-/250908486988?pt=AU_Electronics_Portable_Audio_Accessories&hash=item3a6b4fad4c
http://www.ebay.com.au/itm/iPod-Classic-6th-Gen-6-120GB-160GB-Metal-Face-Cover-Case-Repair-Part-MQHS548-/360466528443?pt=AU_Electronics_Portable_Audio_Accessories&hash=item53ed7ab8bb
You might get these on Ebay im not sure which country you are in this might guide you to one
you could get this on Ebay if you dont have an account you will need to create one
https://scgi.ebay.com/ws/eBayISAPI.dll?RegisterEnterInfo
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
http://www.paypal.com/
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps
How do you charge a ipod touch second gen. 32GB
im having this same problem but it says my itouch 2 gen is a camera?
1helpful
Restoring an ipod
2answers
Ipod classic 80 gb won't charge in bose docking station.
ipod classic will be charge by running itunes programs... now it you dont use itunes, you cannot charge it,...
Unable to sync ipod shuffle.
Thats because you cant sync Music into a shuffle Lol
Hope i helped
__SmartChick10_
Apple ipod classic 160 gb
connect ipod to pc..........let itunes (make sure it the latest version) come up....your ipod icon shows up update (let itunes check if your firmware is up-to-date) if so this should do the trick.
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
