Most likely in tank check valve is leaking or belt is slipping. Belt tension easy to check, should not deflect with thumb pressure. Check valve should not let air escape out of tank. Easy to check. Run compressor till pressure builds to around 50 psi. Then unplug machine from power outlet. Listen for air leaking out of tank. In bad cases, air will actually leak out of intake filter. Replace check valve as needed. Good luck
