Question about Lanier Office Equipment & Supplies
How do I replace an empty waste toner bottle on a Lanier copier model LP126cn
SOURCE:
  • 11 Answers
SOURCE: COPIER
I think there is a cover on the back that you have to remove
Posted on Dec 27, 2007
  • 990 Answers
SOURCE: Full Waste Toner Bottle in Lanier LD040
Hello sir; I believed you talking about LD045, am I right? In this model it doesn't have waste toner bottle, the only place you can clean is imaging transfer unit, after you cleanup the message will be disappear.
Posted on Apr 10, 2009
EmmettPinger
  • 63 Answers
SOURCE: lanier LW324 waste toner bottle full
Open the machine and to the right under the drum you should see the the black powder (toner) going down into container the right lower side  cover must come off. probably a service call will be needed
Posted on May 01, 2009
  • 904 Answers
SOURCE: How do i empty a waste toner bottle on a lanier
What kind of copier is it? On many of the Lanier color copiers, the waste toner bottle is located on the lower left side inside the front door.
Turn the copier off first. Pull the big front door open and turn the bottle with the oil to the left -- the waste toner bottle is the plastic gray tank behind that. Slide it out (carefully) and dump it in a plastic trash bag, then reinsert it.
If you have a different kind of copier, please specify the model and I'll tell you how to get to the waste toner bottle.
Posted on Jul 18, 2010
  • 30 Answers
SOURCE: our imagistics 8130 has the
Hi how are you this is jack ... jack_pak@hotmail.com
Dear you wash the waste toner bottle clearly. But error still your copier you check the waste toner bottle dection SENCER OR IS DIRTY CLEAN IT..
PLEASE VOTE ME .
Thanks
Best Regards,
Posted on Aug 15, 2010
Hoe do I empty the toner waste on an old Lanier 5645?
Its the brown belt thing on the right door, take off the 2 springs and remove the belt assy and empty, very messy...-Carl
Oct 16, 2014 | Lanier Office Equipment & Supplies
How to replace waste toner bottle on lanier SPC231SF
can u mention the model number of lanier copier
Jul 26, 2014 | Office Equipment & Supplies
Full waste toner bottle Lanier LD540C
The boys at the office figured out how to get out and empty... Thanks for all your input... I had sent it on to them.
Jan 21, 2013 | Lanier Office Equipment & Supplies
Can you please tell us where the waster toner bottle is located on a lanier 2145; can't find it anywhere
Hello!
I suppose that it is a printer.
In this printer the toner waste goes to the Transfer Unit.
Open the right door and you will see the trasfer unit. You have to take it out and open it. Then just empty it to a bag.
Take a look at this picture
Jul 21, 2011 | Lanier 1205 Copier
Lanier 6720 U14 error on screen
U14 is a user code for waste toner full.
Open front cover and you will see a clear plastic bottle at the bottom of the machine; lift this out and dispose carefully of waste toner (do not reuse). When fitting back into machine, make sure that inside of bottle is clean as the detection sensor looks through the bottle to see if it is empty and if toner is covering inside of bottle, the message will remain.
Apr 20, 2010 | Lanier 5235 Printer
How do i empty a waste toner bottle on a lanier color copier
Feb 25, 2010 | Lanier 1205 Copier
Lanier LW324 waste toner bottle full
Apr 20, 2009 | Lanier Office Equipment & Supplies
Apr 10, 2009 | Lanier Office Equipment & Supplies
Lanier Copy Machine 3635
Is this a small table top model? They usually do not have a waste bottle. The waste toner accumulates is the drum housing Where hopefully the change drum warning will come on before the waste toner fills up and causes poor copies. I have taken the drum asm apart and vacuumed the toner out.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 03, 2007 | Copystar (023-JF503) Fax
77 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
gggg
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
