Question about Konica Minolta Bizhub Press C6000 Copier
Installed new drums in konica minolta bizhubpress c6000 drum counter did not reset automatically. How do I reset them?
  • Konica Minolta Master
  • 6,850 Answers
Service mode then clear the counters, should have done it before installing the drums.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 08, 2017
SOURCE:
  • 118 Answers
SOURCE: Konica Minolta Magicolor 2400W drum cartrige-how to replace?
Did you buy a whole new drum unit, or just change the cartridge? If so, the fuse may still be blown. Also, you may need to empty the spent toner out of the old cartridge.
Posted on Nov 18, 2008
SOURCE: Sir I have a Konica Minolta magicolor 2530 DL
but this printer doesnt have a main button and 3 lights?
Posted on Oct 20, 2009
  • 15 Answers
SOURCE: how can i get a reset code for my konica minolta
hi U can see trouble list [utility +meter counter +stop 00 stop 01 +counter+trouble] U see all error
Posted on Jan 15, 2010
SOURCE: Can I reset the drum counter for a Konica Minolta
The best way to reset the counter is to replace the fuse on the underside of the printer drum. That is not hard to do, but you have to be careful not to break the plastic tabs holding the original fuse in place.
Posted on Mar 29, 2010
SOURCE: Reset drum counter in Konica minolta bizhub c450,
Press utility/stop-0-0/stop-0-1/0C/no stop/end and exit setting.
It should work.
Posted on Mar 28, 2012
Konica minolta 185 m2
Clear the counters for drum and developer, Replace the drum and developer, run required process, done, Do not reset without replacing because copier uses the counter if you reset without replace code and image problems will begin. Because copier will think drum and developer are new when in fact there are not and voltages set for new will be working on old stuff.
May 26, 2016 | Konica Minolta Office Equipment & Supplies
Reset drum counter 130f
Do not reset drum counter unless the drum has been replaced.. IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Apr 17, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Konica minolta continuous printing
Have you had the developers and drums replaced or does the screen say Replace PC Drums? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the developing units next to the drums. Did you recently replace the drums and the developer if so did you clear the counters for the drums and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developers and a new drums and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the drums unit replace the developer. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. .
Apr 11, 2014 | Konica Minolta Bizhub Press C6000 Copier
Hooper assembly is not working in coping but working in 47 mode
remove the drum assy. and have the the drum and developer replaced along with having the drum and developer assy. cleaned and the senors that are on the assy, then have the proper procedures run after the developer and drum are installed, ALSO have the counters reset to let the copier know that new developer and drum have been replaced
Apr 10, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Reset konica drum counter
has it been replaced???????????????????????/
Has the drum been replaced? If not reset code for drum without replacing the drum is not good. Because the copier works based on the counters. If you reset the counters without replacing the require items, then the copier will adjust certain voltages to certain items such as the drum as those it is new because you reset the counters when in fact the drum is old and so you might be codes and image problems.
Feb 13, 2014 | Konica Minolta Office Equipment & Supplies
C-6402 error code in C6000
no such code in the service manual
Jan 01, 2014 | Konica Minolta C6500 C5500 C6501 C6000...
Konica minolta di3010 how can i reset drum unit?
You replace the drum and developer. Pior to that you clear counters and run the require procedures after because if you reset your drum unit without replacing it the codes will begin to show up the copier works on the counters when you clear it then the copier thinks the drum is new an set voltages as required since it is not new then you get problems . Replace the drum, cleaning blade and developer and do it right!!!!!
Dec 02, 2013 | Konica Minolta bizhub C250 All-In-One...
KONICA MINOLTA BIZHUB163 MAINTENANCE CALL M2
Replace the developer and drum make sure counters are cleared for the drum and developer. because machine works off the counters if the counters are clear it assume new drum and developer are installed and set voltage to the drum and developer based on it, if in fact he drum is not new or developer then image problems and code can appear
try web site below as start to get parts, recommend Konica Minolta tech do it.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jun 07, 2012 | Minolta EP4000/5000 CS/PRO Copier
NEED TO RESET THE DRUM LIFE AND STARTER . NEED THE PROCEDURE TO RESET THESE WARNINGS
Unfortunately The minds at Konica Minolta have figured out how to make the machine Inoperable if you reset the drum and or developer counters, the only way to reset the "change drum" condition on a Biz 350 is to replace the drum AND the developer and calibrate them both when you do it automatically resets the counters... sorry.
Sep 29, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta Bizhub Press C6000 Copier Logo
211 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
