Car Audio & Video Logo
Perry Fiegert Posted on Oct 24, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have a Clarion CZ509A car stereo and when we insert a CD is says it is loading but then spits out the CD and doesn't play
Jerry Kramer
Level 3:
  • Master 3,933 Answers
  • Posted on Oct 24, 2016
Jerry Kramer
Master
Level 3:
Answers
3933
Questions
Helped
882238
Points
12076
Most likely the reader. This can be replaced but much cheaper in the long run to replace the player.
Clarion ADX5655z tape deck problem
Yes step in to the 21st century
My clarion car stereo in my peugeot 206 cc is displaying the message 'ext mute'. I cannot listen to the radio and can no longer play CD's. I've tried turning the system off and on,...
You need to reset the system, disconnect the car battery for 10minutes....... reconnect, enter radio code and should be back to normal.
I have a old clarion factory fitted car stereo in my kia sportage 2000 model its asking me for a code can you assist thanks.
the new stereos are unlocked by an unlock cd.following are the options to obtain an unlock code for the stereo:
1-contact ur car dealer and ask him for the unlock cd.
2-go to some good car stereo shop and ask them to unlock the stereo. 3-if u r a wiz kid, wrie the model of ur stereo in google and search it for an unlock cd and burn it and insert it in the stereo.
How do i connect my i phone 3gs to my clarion cz509a via bluetooth
I have a Clarion Cz509A stereo which did connect via blue tooth to my I phone 3 for over 12 months. However after a car battery was changed they no longer pair together. I have reset the phone, turned it on and off. Checked the pass key is correct with the stereo. Checked hot wire is connected as it keeps time and radio settings when battery is disconnected for over an hour. Tried the head set reset button, but still no detection. What ya reckon
1helpful
It says amp guard when i turn it up
Sounds like you have speakers that are wired incorrectly. Most car stereos require a 4-ohm load, if you wire two standard speakers in parallel it will create a 2-ohm load and cause this condition.
C.d player doesnot play
Hi.
Not all in-car stereo are compatible with computer recorded CD.
Try setting Roxio to "Close Disk" and "Close Session" or "Disk at Once" (try all) while recording the CD on PC.
If that does not work, then the stereo is not compatible with recorded CDs.
Regards.
1helpful
Cd player wont play
put a cd cleaner in to clean the heads so it can read the cd
1helpful
Clarion boat stereo- Error 6
well over time the cd reader in side the unit goes and that what is happen to your unit best solution replace the init
Have a cassette CD player for the car, it will not play a cd after it has played one. difficult to load a cd will constantly spit it back out with either error code EO1 E07
the car stereo does not play cd's that is not a technical problem that someone can talk to be about, and I am not paying to find that out, so i went to someone who could fix it
1helpful
Clarion DB175 cd player
The Clarion manual lists 3 error messages.
Error 2-A disk is caught inside the CD deck and is not ejected.
Error 3-A disk cannot be played due to scratches, etc.
Error 6-A disc is loaded upside-down and cannot be played.
Good Luck.
Top Clarion Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
