Cameras Logo
Rebecca Currier Posted on Oct 24, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a sanyo xacte c40 and it keeps saying problem with the memory card I have tried several cards and still the same can this be fixed
Lawrence Oravetz
Level 3:
  • Sanyo Master 10,558 Answers
  • Posted on Oct 24, 2016
Lawrence Oravetz
Sanyo Master
Level 3:
Answers
10558
Questions
Helped
2700063
Points
29284
Use a computer to format the card. format it with the FAT file system only. Make sure the card 's lock lever os in the down position or unlocked position.
1helpful
2answers
Why does my s120 keep saying memory card write protected?
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
What's your problem?My PNY 16Gb sdhc mememry card keeps saying card error in my camera
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Card is portected dose not record
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
1helpful
I have a sanyo vpc-e890 and it keeps saying the card is locked. How can I fix this?
What does it mean when your Sanyo VPC-X1250 digital camera says "System error?"
try to reset your cammera settings to default
try to change memory card first.
try to format your memory card
1helpful
Whenever I tried to make s shot it says "protected
There are several possible causes for "memory card locked/protected", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
My camera says it can not read the memory card and keeps asking if I want to format the card. I haven't downloaded my photos to my computer yet so i do not want to format. How can I access my...
You can use a card reader to download the pics and then you can format the card in the camera. This one costs $13 at Walmart and can read 32 different cards. 2da6113.jpg
Can not download pictures to pc
Hi...
There is another osption to download you picture to your PC. Try to use a memory card reader, get your memory card in your camera. Inert it into the memory card reader and plaug your card reader to your computer. Now, you can download your picture to your computer.
Regards
PCmania
Camera want take pictures keeps saying its full
Please check the settings on your camera if it has any option to switch between the internal and external memory card. Probably the internal memory is under selection.
Regards,
Srinivas
Top Sanyo Cameras Experts
NOEL
NOEL
Ngoro
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
