It turns over fast like when my crankshaft sensor went
Have you run a fault code test on the system? If not do so and see what shows up.
Testimonial: "Yes , scanner cannot pickup anything from vehicle.. Very weird it's like computer is fried or security anti theft is on, also now there is no sound coming from fuel pump as well , checked all relays and fuses to no avail ?? Help anyone"
You have no power to the PCM
Power Train Control Module PCM
What would make it be my computer when it was fine before?? All I did was change oil sensor and move harness over the screw back in two grounds... Do u think I really fried my pcm by doing this?
Check the PCM power fuse under the hood. I never said the PCM was "fried"
