I was unable to locate a manual for your phone online, but can offer some suggestions to solve your problem.
Most cordless phones beep in battery low, out of range, and other situations. Since it is also displaying the "Searching" message, it indicates that it lost its link with the base due to being brought too far from it or the battery power has fallen to low to permit use as far as it may have worked before.
The quick fix is to simply place the phone into the base / charger. This re-establishes a security link between the cordless handset and your telephone line. This is a safeguard that is used to prevent others with the same cordless phone from merely getting "near your base / charger" and gaining access to your dial tone to place calls on your phone line.
If the battery is low, it should left to remain on the base / charger long enough to fully charge the battery. If the battery fails to charge, there may be an issue with the base / charger; but it is much more likely to be a problem with a battery that has reached the end of its useful life (batteries seldom last more than a couple of years and may not last a single year depending on usage). Either condition will require replacement of the faulty device before using again.
If you need more help, you may want to try Thompson Electronics (if purchased prior to 2011) at 800-448-0329 or their
website; as it appears GE contracts with them for support after the warranty period.
