Make sure battery has a full charge and battery connections all good. The basic tests for, it cranks good but won't start, have a helper crank it while you check for spark at the spark plugs. If spark everywhere, use a gage and check proper fuel pressure. Also check fuel injector pulse
Have you had the battery disconnected?
SOURCE: 2005 chevy silverado won;t start.
i had the same problem, and it turned out the coil pack was moulding inside wich stopped the spark all together, i ended up changing my coil pack and putting on new wires because the ends connected to the coil were very corroded and that cures the not running part just fine
enjoy
SOURCE: How much transmission fluid does my 2005 chevy
start by adding four quarts, then start engine and put thru gears and then back to park and recheck and add as needed,just keep repeating process untill full,make sure you look on dip stick ,it will tell you what kind of transmission fluid to use.
SOURCE: 2005 chevy cavalier problems
NEED TO CHECK THE CODES PROBABLE EMMISSIONS LEAK,GROSS OR SMALL,GO TO ADVANCE AND LET THEM SCAN FOR FREE
Testimonial: "had chevy check the codes and it was the brake sensor. "
SOURCE: 2007 chevy colorado will not start
security lockout on the fuel. 10 mins later it will start
