GC160 160cc Engine - HE GC160LA PHA Logo
Linda Bergeron Eddleman Posted on Oct 22, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pull cord on Honda GC160 power washer keeps jamming up so I can't start it.
David Belitz
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 93 Answers
  • Posted on Oct 24, 2016
David Belitz
Expert
Level 2:
New Friend:
Cheetah:
Answers
93
Questions
0
Helped
44930
Points
270
You can easily purchase a replacement at dealer.
Carlos Rodriguez
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
Problem Solver:
  • Contributor 1 Answer
  • Posted on Jun 27, 2020
Carlos Rodriguez
Contributor
Level 1:
Welcome Back:
Problem Solver:
Answers
Questions
11
Helped
184
Points
I have the same issue. Is not the cord. When I removed the cover, the cors pulls out and retracts fine. Is something else.
In youtube the show to connect the water and pull the cord while you keep the trigger so the air gets out. It works on the video and for almost everyone making comments. Still didn't twork for me. Can anyone help? Thanks.
https://youtu.be/0dG2Ga9p-Pw
2answers
My Honda gc160 engine on 2800 psi washer won’t start
2800 psi your gonna blow the car over with that thing lol
1helpful
Starting a small engine.
place it back up the right way
remove the spark plug
fill the sump to the correct level
pull the cord a few times to expel any excess oil out of the cylinder
remove air cleaner to remove any excess oil from the filter
clean the plug by washing in solvent to remove oil
install plug, prime or choke and it should go
will smoke for a while until the oil in the muffler burns out
Broke the plastic gear inside
You did not say engine make or modell number (i.e. Honda GC160). A great place for parts is Presure Washer Store and Small Engone repa
Oct 23, 2012 • Garden
I have a gc160 honda pressure washer. when trying to crank the washer with the pull cord it acts like it wants to crank but never does.i have changed the sparkplug took the carb. off and cleaned it...
release the water pressure on the pressure gun.that helps.shouldnt have blowby coming out the breather.that indicates worn rings.do a compression check.should be at least 90-130 PSI
23helpful
2answers
My Honda GC160 engine on my pressure washer is next to impossible to pull start. I have checked and added oil to make sure it is full. Still no luck getting it to pull.
honda pressure washer ohv was running great died like someone turned of the switch ! has spark, oil full, sparkplug looks good any ideas please.
4helpful
Power Washer will not start - pull cord seems to be stuck
hi take out the bolts holding the compleat pull starter remove unit pull the cord if it wont move something is jamming it inside if it is ok then the fault is with the motor //seized or washer remove washer pump if engine turns over /pump seized the fault is 1 of the three you have now found out wich 1 starter, motor or pump it will take too long to go over all 3 get back when you have got this far merlinv12
1helpful
Washer want stay running. I can pull choke and it
mr fixit, I have pressure but it just want stay running
Jul 11, 2009 • Garden
Top Honda Vehicle Parts & Accessories Experts
john h
Arnie Burke
Arnie Burke
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
