SOURCE: sanyo spc 3200 cell phone. setting for unavailable or blocked calls
In the settings menu you can go to "security" then "others" then "limit use" then "Incoming calls" then "phonebook only". This will allow your phone to receive only calls from numbers in your phonebook.
SOURCE: iPhone 3G Error 0xE8000001
I just had this problem and it turned out to be... It didn't like my iPod cable. Switched to the iPhone cable and it worked.
Seems to be an iPhone 2.0 prob, or 3g prob, since I was using the iPod cable to sync my old iPhone just fine.
SOURCE: "Ciphering not provided" error message
hi
this happens wen u have an old sim card, try 2 get a new sim card with the same number.
but save the contacts b4 hand, coz u have 2 save them on ur new sim card, and dont worry uur balance will be carried forward.
i hope ur prob has been rectified.
all the best
SOURCE: HTC HD won't connect to my email server
Hi.
Not sure if this helps or ot, as the original question was a little lacking on detail:-)
If you are using t-mobile (might apply to other operators as well, but I could only test on t-mobile) try the following:
Start
Settings
Connections Tab
Connections
Set up my proxy server
Clear the tick box title "This network uses a proxy server to connect to the internet"
Worked for me.
SOURCE: voice mail message icon won't go away
first inactive ur voice mail service. then check outbox if any outgoing sms or voice mail r there then delete it.
