ATVs Logo
Tracey Crawford Posted on Oct 22, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What gear oil do you put in arron cobra 100cc
johnny bonacci
Level 2:
Sergeant:
  • Expert 325 Answers
  • Posted on Oct 23, 2016
johnny bonacci
Expert
Level 2:
Sergeant:
Answers
325
Questions
0
Helped
97218
Points
859
You can use 10-40w motor oil. You don't have to waste your money on special gear oil made just for motorcycles. There isn't anything special about those so called gear-oil type oils.
Hi, my 87 Honda fourtrax shuts off when I put it into first gear, oil is good. I'm puzzled.
Will it run in other gears? If no, sounds like a carb problem .. have it professionally cleaned and set!!
Dies when put in gear
If you didnt flush the fuel tank you probably have water in the carb again.
Place it in the suibn and let uit driy out some more. YOu may still have a wet electricial contact.
Oil pump problems
pump is suffering excessive oil pressure
you are very short on the details of the failure --broken shaft , gears , chain housing etc but I would be checking oil passage blockages, faulty pump pressure regulator spun bearing that the pump feeds into the oil galleys
Apache quad
carb might be clogged clean it
Mar 21, 2014 • ATVs
100cc 4 wheeler diagrams
if its a chinese model you're probably out of luck. some of the motors they use are honda clones so you might be able to find something similar.
Jun 28, 2013 • ATVs
I just bought a 1998 yamaha blaster atv. How much and what kind of oil goes in the gearbox? (the guy i got it from said use plain old 10w-30 oil) Does it use heavy weight gear oil? Transmission fluid?...
Use heavy duty SAE 80W-90 gear oil
Engine oil does work but the oil will not last as long nor will it protect the bearing's/gear's as well as gear oil. Thick dif oil can work to.
Also the gear box is should be sealed.
1helpful
3answers
MY HONDA FOURTRAX WAS VERY LOW ON REAR END OIL AND
I purchased a 2000 Honda Foreman 4x4 and changed all fluids. I put synthetic differential oil in the front and rear differentials.
The problem I am have after about 6 months is the front wheels are not pulling like they use to.
Before I changed the fluids with the front wheels jacked up I could not turn the front wheels but now with very little effort I can turn the front wheels.
Did I make a mistake in using the synthetic oil and if so what is my recourse?
Top ATVs Experts
john h
Renee Knafel-Bullock
ADMIN Andrew
ADMIN Andrew
Are you an ATV Expert? Answer questions, earn points and help others
