You should have its original remote control, to enter into the service mode, and to access factory settings. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
SOURCE: no image astron CRT TV model rc-2132
Service Manual free download schematics datasheets eeprom bins pcb repair
Loose solderings or a
damaged fuse because of a failure in the horizontal (flyback circuit) a flyback capacitor and or shorted linetransistor because a part of the tripler can be bad and have
high voltage that passes through overloaded somewhere leaking on cable and more and get somewhere earth
