Question about Dremel Tools & Hardware - Others
I have dremel 4200 ezchange bit broke inside collet how do i take collet out
    Top Expert:
  • Dremel Master
  • 53,745 Answers
Remove the collet nut
use pliers or the like and pull the collet from the shaft jaws
remove the broken bit
put the collet back in the jaws and refit the nut
Posted on Oct 22, 2016
SOURCE:
  • 218 Answers
SOURCE: collet base removal
Try using a tapered wood screw or sheet metal screw as an extractor. Choose one of a size that will let its tip go down into the broken collet and get a grip when you twist it. If that fails, you might use a screw extraction tool.
Posted on Oct 13, 2008
rowdy45176
  • 2176 Answers
SOURCE: dremel model 365 type 1 collet lock latch is worn
I would go to Dremel.com or call their help line at 1-800-437-3635 and speak with one of their specialists.
Posted on Feb 25, 2009
VtToolMan
  • 704 Answers
SOURCE: My Dremel lock nut won't budge. My collet is
You'll need to use either the built in shaft lock to hold the collet in a fixed position, or use a pair of slip joint pliers to hold the shaft of the bit, while you use the wrench to loosen the collet. Slow and steady should get it loose. Another option is use some penetrating oil sprayed lightly onto the back of the collet to help loosen it from the shaft etc.
Posted on Jul 24, 2009
  • 700 Answers
SOURCE: can't unscrew collet
it is possible that you stripped lock mechanism on the collet, for the beginning, never, ever, use wrench to tighten the collet! just hand tied, if it slips, tight it bit more, but with hands only.
i never used wrench on the collet and never have any trouble with any of my dremels.
to close, just hold firmly in one hand pressing locket button, tighten up with other hand, to undo, reverse procedure.
if you find bit is too lose, then you have collet inserts, find that one which hold bit firmly and use it on this particular bit. standard collet is 1/8" (3.175mm), but in the set there are collets from 0.0394'' (1mm) to 0.177" (4.5mm). do not use wrench...
just inspect now if thread is not stripped, on spindle and on collar, if locket still hold, if these are damaged, you need to change damaged part. and follow the advice :-)
if you find this advice useful, pleasae do not hesitate leave your remark and vote4 for me, thanx!
Posted on Aug 02, 2010
SOURCE: I have a Dremel 300 and the shaft lock assembly
The "nub" on the shaft lock assembly (internal) has worn down and the assembly needs to be replaced.
If you feel competent to open your Dremel yourself (and it's not on warranty) then order the shaft lock assembly from Dremel (early 2011 price: $1.25, not sure how much postage & handling might be). After opening the tool you will find a metal ring and a small piece (the lock) which it holds in place around the shaft where the lock button is located. Remove the old pieces and replace with the new ones and reassemble the tool.
Otherwise you can send the tool to Dremel to be fixed.
Posted on Jan 21, 2011
The collet nut won't completely tighten down to keep a drill bit or what ever I'm using in place .
make sure nothing is broke down inside of it or some type of shavings try sprayin wd40 down it
Feb 08, 2016 | Bosch Dremel 4000 Rotary Tool Kit...
The bits that came with my Dremel are not the correct size
dremel have a collet adaptor to cater for this problem. They are available from the dremel dealer or hardware store
Apr 01, 2013 | Alltrade Tools & Hardware - Others
New to buy collets for Proxxon TBM 115,
You can get the collets from Proxxon 920-757-1718
Oct 12, 2012 | Proxxon MICRO Drill Press TBM115
One end of the 225 t2 is a large receptacle with threads inside and a shaft below the threads.I have no adapter to connect it to the Dremel. The FlexiShaft came with the variable-speed Dremel but no...
To use the flex shaft, you need to remove the bit collet. Included in the kit is a nut looking item--mine is silver. It has a square end and screws on to the end of the dremel. It is simlar to the collet, but is slightly smaller. Then you place the square end of the flex shaft into the nut and screw the shaft on to the dremel.
Hope that helps
Jan 18, 2011 | Dremel 225 Multipro Flex - Shaft...
Can't unscrew collet
Jul 31, 2010 | Dremel 400 Series Xpr Rotary Tool Kit with...
My Dremel lock nut won't budge. My collet is stuck! How can I loosen the bit?
Jul 17, 2009 | Dremel Variable - Speed Multipro Rotary...
Collet base removal
Oct 12, 2008 | Dremel Variable - Speed Multipro Rotary...
Changing a bit on my dremel
Depends on the head you have on the tool. If it takes collets, you need to match the collet size to the shaft on the bit. There are I believe 4 different collet sizes.
You have the threaded shaft which is hollow and connected to the tool. then you put the proper sized collet inside that shaft and half of it will stick out. This is what actually holds the bit. Next, you put the 'nut' on the shaft, but don't tighten it yet. Put the bit into the hole in the nut as far as it willl go, then back it out about 1/8 inch. Now you can tighten the nut by holding down the button on the front of the tool until the nut does't turn any more. You can buy a 'nut' that works with any bit, no collets used, for about $10. Home depot, Lowes etc or online.
If you're not sure what I'm talking about, you can probably find pics of collets etc. by going to google images.
It would probably pay to contact Dremel or look online for the manual also.
Jul 16, 2008 | Dremel Variable - Speed Multipro Rotary...
I can't get the head to open to take out the bit
Unplug it, then while pushing in the little silver button near the head use a wrench on the hex nut and turn counter clockwise about a 1/2 turn. Push the bit in, then pull it out (that releases the little fingers that hold it).
The silver button locks the head so it won't spin while you are changing bits. Always be sure it is released before plugging in or turning on the power.
Feb 19, 2008 | Dremel Variable - Speed Multipro Rotary...
Tools & Hardware - Others Logo
1,674 people viewed this question
Top Dremel Tools & Hardware - Others Experts
cluffermon
Level 1 Expert
Mike
Van Allen II
Van Allen II
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
