I have a 32inch mirai tv but my sky remote control volume wont work so i need the mirai code for the sky remote control i have looked it up but mirai codes dont seem to be there can you send it to me tanx ps its a normal sky remote control
i have the same problem the volume control does not work and none of the codes i tried have worked.i have the same problem the volume control does not work and none of the codes i tried have worked.
You can't post conmments that contain an email address.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience. http://electro-medical.blogspot.com/ http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/
Mirai, made by Chi Mei Corporation in Taiwan, is proving elusive. You can find Chi Mei Corporation. But good luck on finding what branch would offer Mirai support. Tevion 7009 codes list that I have encountered do not list Mirai.. Why not search for a remote that was compatible with Mirai models? You have ended up chasing universal remote codes in the hope that your remote accepts such for that model. I notice you have not listed the model number of the Mirai. Different models were manufactured. Just how you found a Mirai website referring to a TV eludes me. However, you can play with these codes from a prior Fixya volunteer: http://www.fixya.com/support/t578407-mirai_tv_remote_control_set_up_code
0246 is the code 1st cover the top of the remote with your hand press TV you can now move your hand, now press and hold select and the red button togeather the remote light will flash twice enter the code 0246 then press select cover top again and press SKY button it should now control your tv
press and hold select and red until the led blinks twice type in 0 0 6 0 press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
Hi Re Easytouch 42" HD TV - look for Hisense - I took a guess and LCD3204 EU code 376 - remote works but buttons don't tally up - getting there slowly!
Just bought a madeforyou 4:1 remote that is programmed on my PC.
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
