Starts great, mower blades turn. Simply will not engage drive forward or reverse
I will try to give you all information needed to fix the tractor. The first question is have you removed the rear wheels. The rear wheels have a square axle key that drive them. I have provided you with an image below showing the placement of the axle key.
If the axle key is in position, the next check to make is if the drive belt is still on. With the tractor on a level surfaced and the engine off look under the tractor at the drive belt. The belt should be free of slack and go around all of the pulleys.
If the belt is fine put the tractor in neutral and try to push it. If you can push the mower, you know the brake is not the problem. If you can not push the tractor the problem is likely a stuck brake. You will need to mover the break lever on the transaxle to see if it is sticking. If it is stuck you should be able to free it up by spraying a little WD-40 on the brake lever. Then work it back and forth.
Your tractor has a hydrostatic transaxle, I recommend you try to purge the air out of the system. The purging instructions can be found in your owner's manual and I have posed them below.
Next check the brake lever on the transaxle. If it has been sitting for a long period of time it might be stuck on. The lever is located on the right side of the tractor inside of the frame. I recommend working the lever back and forth to make sure it is moving freely.
When you are looking under the tractor, have someone move the shifter. When the shifter is moved, you should see the shifter on the transaxle move. If the shifter is properly attached, have someone start the tractor and let out on the brake. Now carefully look under the tractor at the Trans axle drive pulley. The drive pulley should be spinning. If the pulley is spinning, the problem is most likely a defective transaxle.
