I have a zte zephyr and dont no how to use sd card to move apps
SOURCE: how to use sd card
If you are on Android (which it sounds like you are) checkout this app.
https://play.google.com/store/apps/details?id=com.a0soft.gphone.app2sd
SOURCE: useing sd card
Look at this app on the Play Store:
SOURCE: not move app to sd card
Could you provide your phone series?
If you're using android phone using application (You can search it on Play store)
Keyword : App2SD
If you learn some of app2sd but not enough,
better tool is
Keyword : Link2SD
Hope this may help.
SOURCE: I have a zte model z667t and can't seem to figure
Unless your version of Android allows you to move around app, you need a rooted phone. Then you need a special program, to make it possible to install an app in your external memory. Or at least to install an app that is on your external memory (SD card) into your main memory. Be aware if your phone has a small internal memory (8 or 16 Gbyte) it can be filled up very soon. Not only with the apps, but also with data, like mails and docs (pictures and so on) you have to have in your internal memory, so the phone can access them.
As soon as your internal memory is close to full you can't install anything. SO make sure a few Gb is free before you try to install anything.
