Black Screen with white line across the
I have a Panasonic 27 Inch TV model # CT-2701G
middle of the Screen, so my question is
What could be the cause?
  • 68 Answers
The vertical IC most likely has failed
Posted on Aug 07, 2009
SOURCE:
Tv screen is black except for 1 horizontal line of color
The line is there because the vertical deflection unit - the one that spreads that line across the entire screen to form the image - has failed. Replacing it is a job for a professional, or at least an experienced amateur, and the parts will be quite difficult to find for such an old tv .
May 28, 2010 | Panasonic CT-36DV60 36" TV
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
Panasonic 27 inch TV Model CT-2701G built 9/2003
Hi-
Try removing and reinstalling the cables from the back of your TV.
Keep us posted, thanks for using Fixya!
Jul 14, 2008 | Televison & Video
White lines across top of screen
Need to replace vertical capacitor at vertical Ic.Leaky capacitor.
May 08, 2010 | Panasonic CT-27SL14 27" TV
Panasonic TV-Sound but no picture.
    According to the symptoms, There is a problem in vertical out section.Just check it there must be a capacitor that has been burst or leak.And second one reason could be the malfunctioning of vertical IC.Which is also in the vertical section.
Thanks for using fixya.
Dec 01, 2008 | Panasonic CT-27D12D 27" TV
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
PANASONIC CT-27D30B
Maybe the vertical IC output are damaged you need to replace him
Sep 19, 2008 | Panasonic CT-27G14 27" TV
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Televison & Video Logo
193 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
