SOURCE: remote codes
Most remotes have a "Search for Code" or learn function. However, since Comcast currently supports 8 different types of remote controls, your best bet is their website. This link takes you to all of the remotes they currently support, find your remote and click on the View Manual link next to it.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
More than likely you will have to use the "Search for Code" option, as I did not see your particular TV brand on the few that I checked.
SOURCE: how to unlock the parental control on Advent Q1435A
Press and hold the display for some time (say 20sec) and this should solve the problem. It solved the problem for me
SOURCE: trying to unlock my rating guide on my haier tv w/out remote
Keep it unplugged for an extended period of time. It should lose all of it's settings unless its a really new TV.
SOURCE: i forgot the password for unlock the parental control
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
Hold down MENU on the remote and VOLUME DOWN on the TV it?s self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
