LG KU990 Viewty Logo
Posted on Jul 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LG Viewty battery discharges quickly .....
I understand that because the phone has a large touch screen, the battery won't last as long as with other mobiles I'm sure it should last longer than 16 hours???!!!
I'm not a heavy user but even on standby I can't get any longer than possibly 30 hours and if I start to actually use the phone, it goes down to 12.
I have noticed though if the battery is only charged for just a couple of hours, it seems to last longer than putting it on a longer (overnight?) charge.
Anonymous
Level 3:
  • Master 590 Answers
  • Posted on Jul 29, 2009
Anonymous
Master
Level 3:
Answers
590
Questions
Helped
149036
Points
1722
Charging duration does not connect to battery lasting duration in any way.Optimal charging time is 3 to 4 hours.your battery will drain soon if you keep your touchscreen pressed continuously in your jeans pocket.Keep bluetooth switched off. Reduce the brightness of your mobile display. Play music threw headphone rather than using loudspeakers.
Anonymous
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Aug 12, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
0
Helped
4370
Points
14
When you put your phone on charge overnight you burn out your battery and it runs down alot faster so you should only charge it for reccomened time and it should be ok cause i have the same phone and i charge mine for recommened time and remove it from charge and it lasts about 4 days
Anonymous
Level 1:
New Friend:
  • Contributor 26 Answers
  • Posted on Mar 02, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
26
Questions
0
Helped
39977
Points
79
The battery has some problem. Happens with my one too. Use a nokia if you want better battery.
My phone keeps turning off even when the batteries full. and then takes a few tries to turn back on.
had the same problem since New Year. Bought a replacement battery from eBay last week and now its back to normal. What ruined my last battery was using an in-car charger. Only ever use the wall charger, and discharge the battery completely at least once a month to keep in good condition.
EARLY BATTERY DISCHARGE
Magnet should not cause any additional discharge on battery, if you are just looking at the battery. however, it is ill-advised to keep a magnet near your phone as has negative effects on the performance.
your magnet is a possible cause. try removing it, if it still has the same symptom, then try replacing the battery. If not, then there may be a leakage problem with your unit.
3answers
New battery loses charge to quickly only lasts 24 hours have tried another still the same problem have fitted phone cover
For better battery performance, perform the following tasks,
1. Switch off the bluetooth. If needed put into hidden mode.
2. Switch off the wifi netword scanning (if applicable)
3. Reduce the screen brightness.
4.While keeping in pocket, take care to ensure that the mobile screen not at all touched or pushed inside pocket even though the screen is locked.
5. Charge th emobile phone for continuous 5 hours and dont charge until fully discharged. Follow this for atleast 5 times.
Then you can see the improvement in batery backup time.
I hope this is helpful to you
4helpful
My LG Viewty phone has been frozen for 4 days. The only thing I can do is answer calls and make calls to numbers in my call register. Everything seems to still work perfectly, exept for the screen. I've...
My LG KU990 viewty screen has frozen....meaning...the touch screen doesn't respond when I press it.
I can answer the phone and only call numbers i've already.
Does anyone know how I can fix this
I stupidly did not get it insured
I've turned it off and left it off for some time, taken the sim card out, but this doesn't help. Does anyone have a solution?
I have a lg viewty touch screen phone, the touch screen doesnt work but i can still see the screen perfectly, do i buy a whole screen or just a lcd part??
You just need to buy a replace touchscreen. You can replace it. They run about 15 dollars from ebay and are pretty straight forward. Here is a link on how to replace the touchscreen on the Ku990.
How to replace touchscreen on LG Viewty KU990
2answers
Lg prada rapide battery discharge even with a new
it is a software problem go and check at www.lge.com ROM for ur mobile and update it , or go to service centre for that it is a software issue
pls rate me fixya for my help
4answers
Unlock codes for lg ku990
try 1234, 0000, and the last 4 digits of your phone number
46helpful
13answers
KU990 Viewty's battery loses charge very quickly
I saw on another forum two good tips.
1. Do not use a case with a magnetic clip.
2. Take off the battery cover and put tape over the two small etched squares that you can see one at each end on the inside of the cover.
I did this and up to now my battery has doubled its life. Still two bars after 1.5 days of medium use.
Terry
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
