Hi...getting "LOCAL IP ADDR INVALID" on one of my INTER-TEL PHONES....82622V2
It has been configured exactly like all the others... B1L
  • Computers & ... Master
  • 4,290 Answers
Bill
what about the sub net mask is it exactly the same as the others ?
Has the subnet mask been used to create a separate network ?
what is the subnet mask ?
is it 255.255.255.0
does it have numbers in it that are not 255 or 0 ?
if the number is different to this you have subnetting on your network and may need to use a particlar ip address to fit into the subnet.
Posted on Oct 18, 2016
Testimonial: "Hi Brett....Thanks for answering back ! ! Yes everything is exactly to the T... Static IP address 192.168.0.169 DEFAULT SUBNET 255.255.255.0 DEFAULT GATEWAY 192.168.0.1 REMOTE IPC IP 192.168.0.200 REMOTE UDP PORT 5567 REMOTE TCP PORT 5566 TFTP SERVER URL 192.168.200.202 ENABLE DHCP ?---> NO PHONE VLAN ID ZERO PC PORT VLAN ID ZERO Exactly other phones have... B1L"
  • Brett Duxbury
    Brett Duxbury Oct 19, 2016
    what else is connected to the network ? Is 192.168.0.169 possibly being used by some other device or is part of a DHCP lease ?
    check security settings on cisco router or switch maybe ip address or mac address is being blocked by it .
SOURCE:
How do I pick up a call at another extension?
This is not a 5330 question but a system question. This phones will work on more than 1 system. On a Mitel 5000 or Inter-tel 5000 system the feature code is press the digit 4 then dial the extension number. Hope this helps.
Jul 17, 2014 | Mitel 5330 IP Phone
How to know the MAC address of my infoprint . In the config menu I got one but contains only 5 groups
If the printer is configured and has got a TCP/IP address, you can get the MAC mapping from any Windows PC in the same network like this:
Start -> Run Command -> enter "CMD" and press Enter -> type the command, PING ip.addr.of.printer (enter) and then ARP -a ip.addr.of.printer (enter).
If your network's IP addresses are centrally managed, ask your system administrator if it's possible to temporarily assign a fixed IP address for diagnostic purposes, then assign that address to the printer and do as described above.
Oct 30, 2009 | IBM Infoprint 1622 Laser Printer
WHAT IS THE PROXY FOR FREE IDEA GPRS
free Airtel GPRS is working.
In NUTSHELL you had to do only 3 things
  1. Enter your cel no. into USER NAME/NO. Field (If it is blank)
  2. Change access point / APN to airtelfun.com or airtelmms.com
  3. Configuring your application for following proxy setting…
- If u r using airtelfun.com
IP Addr : 100.1.200.99
Port no. 8080
- If u r using airtelmms.com
IP Addr : 100.1.201.172
Port No. 8799
That all about settings!
May 17, 2009 | Nokia 6300 Cell Phone
How to enter IP address of IP PBX into phone 770.4600
The Guide is here. You have to register for their site to get the instructions however.
Mar 14, 2009 | Inter-Tel Axxess Corded Phone
On calling anyone they cannot hear me
Are you using speaker phone? Are you using the Hand Set?
If you are using the speaker phone, the first thing is to check the back end configuration of your IP phone system and Make sure that that Station has the Microphone Feature enabled. If it does, then the next step would be to configure a different phone with your same extension and ip. If that phone works fine, then it tells you that it is the microphone inside the original phone that is bad.
If it doesn't fix it, then the problem lies on some of the settings within your phone system.
Some other simply things to try if using the Handset, is 1) Replace the cord from the telephone base to the handset. 2) Grab a similar headset and hook it up to your phone. Test calling someone internally in the office, and out of the office.
Mar 09, 2009 | Inter-Tel Axxess Corded Phone
Inter Tel Encore will not roll over
That is not a function of the phone system. You need to call your telephone company and have them configure your lines to hunt
Dec 15, 2008 | Inter-Tel Encore Phone
Inter-tel axxess cabling
Possible loose connection in the telcom room or room jack. Try re-punching all the connections that relate to that phone and test again. No special cables needed for exec. phone, just a single pair as any other.
j
Dec 09, 2008 | Inter-Tel Axxess Corded Phone
Inter-tel 660.300 Intertel Premier 24 Button
Line could be dead from local provider (Verizon,etc.).Could be a bad port on the phone system. Maybe a bad connection into phone system. What Intertel system do you have?
Oct 16, 2008 | Inter-Tel 660.3000 Intertel Premier 24...
Inter-tel Access
You definitely need to have a local phone installation company come in and help you with this. Axxess system setup and programming is extremely complicated for someone that has not worked with it and it requires specific software to make program changes. If you know the company that installed (or services) the system you should call them.
Nov 09, 2007 | Inter-Tel Axxess Corded Phone
Open Questions:
Computers & Internet Logo
260 people viewed this question
Ekse
Alun Cox
