SOURCE: Nortel T7316E, How to make headset work ?
Look in the System coordinator guide 5.0 for HandFree
Select type of handfree
You must set the Handsfree at: auto
Its in the deep programming
Your going to need Business Series Terminals programming overlay to put over the phone.
I beleved this will FIX it OK!
SOURCE: How to change time on my T7316E Nortel phone
Step 1
Press the FEATURE key followed by **8463
Password
Retry
Step 2
Press 266344
on the dial pad buttons to enter the DEFAULT password. Your password
MAY BE DIFFERENT! The display will show the following options:
Hour: 01
Next
Change
Step 3
Select CHANGE - the display will show the following options:
Hour: __
Cancl
Step 4
Use the dial pad buttons to enter the hour. You must use two digits for
all hours (i.e. "08" for 8 o'clock). You will be prompted to enter AM
or PM. Select CHANGE and OK to choose PM.
AM
OK
Change
Step 5
After you have entered the hours, select NEXT. The display will show
minutes as 00. Use the dial pad buttons to enter the minutes. If you are just changing the time, press the
RELEASE (RLS) button to end your session. The time will be changed and
the date will remain the same.
If you want to change the date, select NEXT.
Minutes: 00
Next
Change
Step 6
The display will show 99 as the year. Using two digits, enter the year using the dial pad buttons (i.e. "05" for 2005).
Select NEXT, and repeat to change the month and the day.
Year: 99
Next
Change
Step 7
Once you have entered the day, press the RELEASE (RLS) key to end your session. This will save the changed time and date.
SOURCE: change extension number on Nortel T7316E model
Well ~ eagleeigh731 has it mostly correct, do what he said to do and get into the programming --> find SYSTEM PRGRAMMING --> hit next until you find CHANGE DNs--> OLD DNs (this is the old extn#) 222 then type in NEW DN 431--> then hit the end or release button.
Voila your new extension is now there... to check dial FEATURE 0 then press the intercom button, the new extension should be there.
SOURCE: T7316e Nortel Meridian Norstar Telephone MANUAL
Not too sure what type of manual you are looking for, but here is a useful link to have for a Norstar system information.
http://www.alphatelecom.ca/meridian_norstar_manuals.htm
SOURCE: changing name in nortel T7316E handset
We would like to change the name displays on our phones
