I have a Toshiba but is asking for password before to enter the OS.
SOURCE: BIOS Resetting...
Please open this link this will help you
http://www.thenetworkadministrator.com/biospasswords.htm
And dont forget to rate FIXYA if it didnt help please reply but dont rate any rating
Thanks
Regards
SOURCE: default bios password toshiba satellite a135-s2276
I have a Satellite A135-S2356 that had the same problem. I tried the solution from PCTServices above and it worked great.
"Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back mylar from JOPEN1 solder pad. Short JOPEN1 solder pads for 30 seconds. Replace mylar. Replace memory modules. Replace battery. Power up unit. If all is well, replace memory cover and screw."
Just short the two little solder pads and it worked great! I thought I would have to send it back to the manufacture but I am back in buisness. Thanks for the help.
Bryan
what you need to do is pull both the laptop battery as well as the cmos battery. in some instances, the battery can be pulled, but on other models, i have seen the battery as an actual physical part on the motherboard or somewhere where it is not easily accessible, in which case you need to clear the cmos by using a jumper on the motherboard, since it is a laptop, they are all different. you may need to see if you can locate a copy of the motherboards schematics and go from there.
SOURCE: Toshiba sat A135-S2266 BIOS password reset?
Ok turn the unit over to where the RAM is open the door( Toshi in off mode) remove both rams and look for two brassy flat peices of metal. Take a paper clip and bridge the two together...woosh !
Bios is reset.. no password. replace ram correctly close the door and start laptop as normal.
Please rate our help to keep service online
SOURCE: I need the bios reset password for a toshiba laptop
there is no actual password. you need to remove the ram and short out two pins underneath the black plastic they look ike two E's connected like E3. use a flat blade screwe driver. do this while powered off!
