Computers & Internet Logo
C
Carolyn Dowdy Posted on Oct 18, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to Create a Shutdown Icon on my Desktop? - Computers & Internet
CrazyAxel
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 56 Answers
  • Posted on Oct 18, 2016
CrazyAxel
Expert
Level 2:
New Friend:
Night Owl:
Answers
56
Questions
Helped
3166
Points
211
Just create shortcuts for both actions using the following steps: Step 1: Go toDesktop and Right Click then go new and Click Shortcut menu. Step 3: Change the Setup Icon Go to Shutdown Button Properties then click Change Icon and Choose your Icon Done. Step 4: Right click the shortcut and select Pin to Start
tip
To create a shutdown,reboot, logoff icon on your desktop (XP)
Right click on an open area of the desktop>> Select New>>Shortcut Enter in
shutdown -s -t 0 (for shutdown button)
shutdown -r -t 0 (for Restart Button)
shutdown -l -t 0 (for Logoff button)
Note: Only enter the text in bold.....and not the text inside bracket.Press Next For the name, enter Reboot or anything you like.
Click Finish.
on Aug 09, 2011 • Computers & Internet
No shutdown icon at start icon
Right click on the desktop
Click [New] [Shortcut] to open the Create Shortcut Wizard
Type [shutdown -s -t 00] without the brackets.
Click [Next] and type a descriptive name of your choosing for the shortcut
Click [Finish]
or you can do this
go to run type regedit then
go to hkeycurrentuser\software\microsoft\windowsNT currentversion\program manager\restrcitions
then change the noclose value to 0
My laptop acer aspire5920 is not shutting down due to removal of my shutdown file from my laptop due to unknown reasons.
Hi dear,
Create Icons for Shutdown and Reboot If you find it annoying to access the Start Menu for shutting down or rebooting the computer, create a shutdown and reboot icon for the desktop.
Desktop Shutdown Icon Right click on the desktop
Click [Finish]
Add a bit of class to the shortcut by assigning it a custom icon. Right click the shortcut, click [Properties] and select the [Shortcut] tab. Click [Change Icon] and select from the icons that are displayed.
Desktop Reboot Icon Right click on the desktop
Type [shutdown -r -t 00] without the brackets.
Click [Finish]
A Final Note: If you happen to be as fanatical as I am about having nothing on the desktop, drag the new icons into the Quick Launch area of the Taskbar.
then use it.
if not resolve it
then use following step ;-
click on start then go to RUN and type SFC /SCANNOW
press enter
this command recover all windows lost files, if it will ask windows CD then enter the windows disk.
bye take care
good luck
veeru
tip
Start Menu Editing
To create a reboot icon on your desktop:
Right click on an open area of the desktop Select New/Shortcut Enter in
"shutdown -r -t 00" - no quotes Press Next For the name, enter Reboot or anything you like.
Click Finish.
tip
Create Desktop Shutdown/Lock/Restart/Hibernate Shortcut Icons In Vista
1. Right click an empty area of your Desktop
2. Select New>> Shortcut
3. In the text box titled: "Type the location of the item:" Enter the Command for the particular shortcut you would like to create. I've listed all of the commands below that activate their respective shortcut:
Hibernate rundll32.exe PowrProf.dll,SetSuspendState
Lock Rundll32.exe User32.dll,LockWorkStation
Restart Shutdown.exe -r -t 00
Shutdown Shutdown.exe -s -t 00
Sleep rundll32.exe powrprof.dll,SetSuspendState Sleep
4. Once you've entered the command, click "Next"
5. Vista will now ask you what you would like to name your shortcut. I've always just given it the name of its function (EG: Shutdown or Shutdown System).
6. Once you have named you shortcut, click "Finish". Your new shortcut will now reside on your Desktop. Simply double click the icon to activate the command.
Note: If you do not like the look of the "default" icon that Vista has given it, you can change the icon to a different one. Here's how:
1. Right click the shortcut icon
2. Select Properties
3. The shortcut properties window will now be displayed. Click the "Change Icon" button.
4. The "Change Icon" window will now appear. Here, you can select from the many available system icons. Click the icon that you would like to use as your shortcut icon and then click OK.
Your Desktop shortcut icon will now revert to the selected system icon.
That's it! Have fun!
on Oct 08, 2010 • Computers & Internet
Shut down icon
That is a strange problem.
I will help you to create a shortcut on your desktop for that icon, whenever you need to shutdown your computer, just click that shortcut on the icon.
Right click on the Desktop.
Left click on New > Shortcut.
In the Type the location of the item: textbox enter
%windir%\System32\shutdown.exe -s
The -s parameter is used to shut down the computer.
The following two parameters can be used with -s:
-f Forces running applications to close without warning.
-t xx Set timeout for shutdown to xx seconds.
The following command would shut down instantly.
%windir%\System32\shutdown.exe -s -f -t 00
Click the Next > button.
In the Type a name for this shortcut: textbox enter
Shutdown My Computer (or some other name of your choice)
Click the Finish button.
Whenever you want to shutdown your computer, click the shortcut on your desktop that says ShutDown My Computer, and your comptuer will shut down the usual way, the way it used to shutdown.
Actaviosan
tip
Here's how to create a shutdown shortcut on your desktop
Instead of going to the start menu, choosing shutdown, then waiting for the computer to shut all the programs down, you can create a shortcut on the desktop to do it quickly. You can create a shutdown, restart, or a logoff icon on your desktop which will work a lot quicker than using the usual buttons in the start menu.
1. Go to your blank desktop
2. Right click on a blank space and a menu will appear
3. Choose New from the menu
4. Then choose Shortcut
5. Where it says type the location of the item type in shutdown.exe -s
6. Then press next
7. Now enter a name for your icon. Mine is called SHUTDOWN NOW
8. Press next
9. The Shutdown shortcut will be on your desktop
Different combination you can type in when creating a shortcut to shutdown, restart, or logoff.
Shutdown.exe -s
Shutsdown your computer in 30 seconds and will close all programs and ask you to save all work.
shutdown.exe -r
Restarts your computer in 30 seconds.
shutdown.exe -l
This one will logoff your computer back to the welcome screen where you will need to login again.
shutdown.exe -s -t 1
Shutsdown your computer in one second. the -t 1 tells it how long to wait. (one second in this case) You can put -t 10 or even -t 1120.
shutdown.exe -s -t 15 -c "Goodbye you idiot"
This is my favorite code. It will shutdown in 15 seconds and have a message in the box saying "Goodbye you idiot"
The -c "bla bla bla" stands for a comment.
Notes:
* to stop the computer from shutting down type shutdown /a into the run box located in the start menu..
* -f will force everything to close immediately without asking to save anything.
on Jan 29, 2010 • Computers & Internet
tip
Create shortcut icon for shutdown and restart on desktop
For easy usage you can now create icon for shutdown and restart on desktop. Right click on desktop in that do to new and then select shortcut. Now you will get create shortcut window will appear. I this you will see one text box for select the location of the item. In that place you need to write "shutdown -s -t 00" without double quotes. and click next. Here you will find the option t rename that icon. after that click on finish.your shortcut is ready on your desktop. This icon for shutdown. If you want to create icon for restart.Follow the same steps above and in the of location of item write "shutdown -r -t 00" without double quotes..
on Dec 23, 2009 • Computers & Internet
tip
CreaCreating Shutdown Icon or One Click Shutdown:
Navigate to your desktop. On the desktop, right-click and go to New, then to Shortcut (in other words, create a new shortcut). You should now see a pop-up window instructing you to enter a command line path.
Use this path in "Type Location of the Item"
SHUTDOWN -s -t 01
If the C: drive is not your local hard drive, then replace "C" with the correct letter of the hard drive. Click the "Next" button. Name the shortcut and click the "Finish" button. Now whenever you want to shut down, just click on this shortcut and you're done.
tip
SHUTDOWN -s -t 01
Grand Canyon Tech
Grand Canyon Tech
