This issue may occur if you deploy Outlook 2003 with the
Microsoft Office 2003 Custom Installation Wizard and specify a
personal folder
(.pst) file in the Windows Installer transform (MST file) by using
the
Default location for PST files path
option. The problem occurs
because you specify a file name instead of a folder path.
To resolve this issue for future installations of Office,
use the Custom Installation Wizard to edit the MST file. To do this,
follow
these steps:
- On the Change Office User Settings
page
(page 10 of 24), expand Microsoft Outlook
2003, expand
Miscellaneous, and then click PST Settings.
- In the right pane, double-click Default
location
for PST files, and then type the path that you want in the
Default location for PST files box.
For example, type
%USERPROFILE%\Local Settings\Application
Data\Microsoft\Outlook\.
- Click OK, and then follow the steps to
complete the wizard. When you have corrected the MST file, deploy
Office by
using the correct MST file.
To resolve this issue for an
existing installation of Outlook
that is experiencing this problem, specify the .pst file by using
the
Mail icon in Control Panel.
Or If you are receiving and Err like
Error message when you start Outlook: "Unable to open
the Outlook window," "No profile has been created," or "The list of
Profiles cannot be loaded"Follow the step's below:This issue may occur on a computer that is running Windows XP if the
Outlook.exe file was configured to open with the Windows program
compatibility mode setting.
When you set compatibility for Outlook to Windows 95 or to Windows
98/Windows Millennium Edition, Outlook displays this error message. This
is because the location of the Outlook Profile information in the
registry differs on a Windows XP-based computer.
To resolve this issue, follow these steps:
- Locate Outlook.exe.
Outlook.exe
is typically located in one of the following folders, depending on the
version of Outlook that you are running:
- Microsoft Office
Outlook 2010 C:\Program Files\Microsoft
Office\Office14
- Microsoft Office Outlook 2007 C:\Program Files\Microsoft Office\Office12
- Microsoft
Office Outlook 2003 C:\Program Files\Microsoft
Office\Office 11
- Microsoft Outlook 2002 C:\Program Files\Microsoft Office\Office 10
- Microsoft
Outlook 2000 C:\Program Files\Microsoft
Office\Office 9
- Right-click Outlook.exe, and then click Properties.
- On the Compatibility tab, click to clear the Run
this program in compatibility mode for check box.
- Click
OK.
- Try to start Outlook. If
you receive error message again, use Method 2.
Regard's
Pcs365.8
