I have a NEWish, Danby portable Twin Tub washer / spin dryer ... the spin side is not spinning. It drains but NOT spinning. Do you know what the problem may be. this is less than 4 months old; was sold AS IS, therefore, no warranty available
SOURCE: Washer fills, but doesn't do anything else
if it fills then the power is there open the lid and make sure all connectors are on to the timer if they are then more then likely u have a motor problem check carbon brushes if these are low then the motor wont turn the drum if there is no carbon brushes ull have a module if this is faulty most of the time its cheaper to replace the washer m8
SOURCE: won't drain or spin out
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
SOURCE: Washer Won't spin & smells burning when it goes on spin
Hi there.I think it could be that when the belt was changed the bolt wasnt tightened onto the flat side of the spindle.I am talking about the small pulley that comes off to replace the belt.It has one flat side in which the bolt needs to be otherwise it might just spin because the laundry weight. Quick question I have this machine and it needs a replacement belt.I cant find one anywhere!!!!Where were you able to find one???? Good Luck
SOURCE: Danby front loader becomes very loud during spin cycle
Most likely this will be the drum bearings.
Bearings normally last quite a long time but some will fail sooner than others. Quite often bearing failure is due to a faulty drum shaft seal which allows a small amount of water through and in to the bearings. The bearings then start to rust, which then accelerates the wear on the bearings.
Replacing the bearings needs well above average DIY skills to do, so unless you feel confident to tackle the job, can get hold of a tech manual, and can get hold of new bearings, it's time to call an engineer.
SOURCE: Danby front load washer Will not spin motor runs
I just had the same thing happen.
Clean the lint trap at the bottom left. Use a coin to unscrew the cap, then unscrew the filter that is is front of the pump. If the water is not ejected, then the machine will not spin faster.
