J
Jeff geesaman Posted on Oct 17, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there a switch or something I need to do to get my tvs to get analog channels clear when I am hooked to cable?
I had a 2015 trailer and was able to get about 70 clear channels at the camp ground I have a seasonal site at. I just purchased a 2016 Montana High Country and after programming the tvs I only get 3 clear channels. The rest are very distorted. It says that the 2 clear channels are digital and the rest that it detected are analog.
Lawrence Oravetz
Level 3:
  • Audio Player... Master 10,558 Answers
  • Posted on Oct 17, 2016
Lawrence Oravetz
Level 3:
Answers
10558
Questions
Helped
2700119
Points
29284
See if the tuner on the TV has a provision to add both analog AND digital channels as a choice. If so, then select that and then do a new channel search. Ask if the cable company uses standard or irc channel spacing and set your tuner on the TV to match.
1helpful
Ematic AT102 How do you program it to receive the cable channels when no cable box is needed?
Unfortunately, the Ematic AT102 does not have a tuner for cable television. It only has a ATSC (digital over-the-air) tuner. You need to connect it to an TV antenna and then search for channels. Depending on where you live, you may need an external antenna to get sufficient signal strength to receive local channels. See http://www.tvfool.com for signal strength information in your area.
Older cable signals are NTSC (same as analog over-the-air). Newer digital cable is QAM. (Some channels are broadcast as clear QAM which don't need a cable box with some tuners/TVs.)
To record your cable, you will need a different type of DVR/set-top box. An old VCR or DVD recorder with an NTSC tuner would work to record analog cable. There are a few ATSC converter boxes that also support clear QAM. This is one of the models: http://www.solidsignal.com/pview.asp?p=CM-7003 .
I wish that I had better news for you. Other options are available for NTSC, ATSC or QAM tuners. Please add a comment with more information about your cable service if you'd like extra information on these options.
I inherited a Sharp LCD 32" flat screen TV that's only about 2.5 years old. It worked fine at its previous location. Upon bringing it to my house, I've tried disconnecting the cable from my TV &...
Try going into your setup menu. Look for a setting for "Cable/Air". Try switching it to Cable and then doing a channel search. If you are using a cable box try setting channel to 3 on tv. Those are the two easiest things I can think of off the top of my head without seeing it.
No sound on sony tv
Your set may have a choice of audio sources and outputs in the basic (initial) setup since it is not uncommon to mute the internal speakers and get your sound from a home theatre system or receiver. Also, if you are using S-video connectors between converter and set, there is no sound path, this is video only, and you will have to add a couple of cables, likely with RCA connectors, between the two.
For reference: Audio cables: Red=right channel, White=left.
No channels recieved
If you have cable already, you do not need to use a converter for your picture. You would still just hook your coax cable to the tv right from the cable inlet. The converter is for over the air signals only, so you would place it between your bunny ears and the tv to convert your signal for your tv.
We have an older tv with an indoor vhf/uhf antenna. We have hooked up the converter box according to directions and even watched a video showing how to hook it up. However, with the tc on channel 3 and...
Sounds like a connection problem, if coaxial connection was made and box is turned on, then something should show up on channel 3. If rca composite connection was made something should show up on video 1 or 2. Make sure box's power button is pushed to 'ON'.
I hooked up my magnovox dtv converters to my bedroom and living room tv's. They come on, scan channels and give me 6 public broadcasting channels, which are very clear. BUT I can not get anything else! I...
You need to get a converter with an "analog passthrough". The magnavox converter that you have is blocking the analog signal from reaching your TV's tuner. The RCA converters that your friends have must have the analog passthough feature that not all converters have.
HDTV converter box only brings in 3 channels
We have a pretty good signal when we use the antenna but when we hook up the converter box we get no channel weak signal no channels we have a amplipher on it it does not help .
1helpful
Hooking actual live coaxial from Cable Co. to Insignia Converter Box ...
Based on the specs that I have read I am going to say you cannot hook up cable to the converter. Best thing to do would be to call cable company that provides service there and see if it was turned off on the billing side they probably just didn't come out and disconnect from the pole. That might give you service but missing some features such as tv guide channel. Now some tv's have tv guide built into them and maybe in the move that feature on the tv was turned off it they were using it that way before. Here is what the specs say about that converter:
Use this digital-to-analog converter to convert digital TV broadcast signals to analog signals on analog TVs with antenna-based reception.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Dig sig
it only has an ATSC tuner, and no clear-QAMuning options
 Grubhead
Grubhead
SmartAviator
SmartAviator
