Tablets & eReaders Logo
C
Cindy young Posted on Oct 16, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need data on my tablet and I can't go through virzon can I go through my phone
Dariusz Zalewski
Level 3:
  • Master 1,095 Answers
  • Posted on Oct 17, 2016
Dariusz Zalewski
Master
Level 3:
Answers
1095
Questions
0
Helped
297355
Points
3055
If you have hotspot plan on your phone then you can. All you have to do is to turn on hotspot feature on your phone, turn on wifi on your tablet and connect to your phone/hotspot.
Hi, can u remotely restart my tablet? it's been frozen for 2 days
there is no possible way to remotely restart a tablet but there is a way to do it press and hold the power key for about five seconds and this will force the tablet to turn off or reboot the android system and it should be fine however if it freezes again this can be an issue with the android system itself and the tablet will need to be reset (resetting android for some tablets: press and hold the power and volume down (or volume up) key and this will boot to recovery mode for some others say like samsung press the power volume up (or down) along with the home key to go into recovery mode)
Proscan tablet stuck on android screen
The Issue
The problem usually presents itself like this: you boot up your tablet and the tablet reaches the Android logo and hangs there and never moves. If you attempt to restart or reset the tablet through the Android recovery mode that too does not help and the tablet is basically useless as it will not start-up.
Why is my tablet stuck on the Android Screen?
The issue is caused by a corrupted or none functioning Android operating system and the only way to get your device back to a functional state is to reflash the original firmware or a compatible version
Devices will no work
This will work on any Android tablet with the issue, however it works best with tablets that look like the Alldaymall A13 MID or the Irulu AK304 which we have tested this on and others, it's a simple matter of finding the correct fir
What will I need to fix this Issue?
You will need:
1. A MicroSD Card.
2. A means of connecting the MicroSD card to the PC/a MicroSD Card to USB converter
3. Your Tablets Firmware:
Alldaymall A13 MID Firmware:
Irulu AK304 Firmware:
4. Download thoenix Card
How to Fix your tablet that is Stuck on the Android Logo?
1. You will need to get the relevant items from the list above that includes the MicroSD card, the SDCard adapter,phoenix card tool and your appropriate firmware for your model tablet. show you what to do step by step
I want to be of use my Ellipsis tablet to download apps over Google play without using Wi-Fi but using my data instead how do I do that
Tablets do not normally have cellular data access. There are two common ways to obtain it. One is to obtain a compatible "aircard" from your cellular carrier, which will allow the tablet to access the call towers on your data allowance. The second way, and the most common, is to have a cell phone that can act as a wifi "hotspot". You set the cell phone to use data rather than wifi, but the tablet links to the cell phone via the wifi hotspot and uses the cell phone as the data link to the carrier. The tablet therefore doesn't know the difference between regular wifi and the cell phone hotspot.
CANT POWER DOWN OR DO A FACTORY RESET
How to Factory Reset Your Android Phone or Tablet When It ...
www.howtogeek.com/.../how-to-factory-reset-your-android-phone-or-ta...
Dec 6, 2012 - You can even perform a factory reset when your Android phone or tablet ... If You Can't Boot ... If your device isn't on this list and none of the above methods work, do a Google search for the name of your device and "recovery ... If your device freezes at any point, hold down the Power button until it restarts.
What to Do When Your Android Phone or Tablet Won't Turn ...
www.howtogeek.com/.../what-to-do-when-your-android-phone-or-tablet...
May 16, 2015 - You can't just plug it in and try to turn it on immediately - you'll need to give ... How to Factory Reset Your Android Phone or Tablet When It Won't Boot ... To do this, you'll first need to power down your phone or tablet and then ...
Como puedo desbloquear una Tablet pc7518A
translated to English is:
As I can unlock a Tablet pc7518A
Hold down the Power button and tap Volume Up. You'll see the Android system recovery menu appear at the top of your screen. Select wipe data / factory reset with the volume keys and tap the Power button to activate it. Select Yes - erase all user data with the volume buttons and tap Power.
How to unlock an Android phone tablet
How to Factory Reset Your Android Phone or Tablet When It Wont Boot
How do I do a auto hard reset on my polarold internet tablet pmid701c and can it be able to download Google plays tore
Differnt hard reset/factory wipe methods for tablet pc, Hard reset or factory wipe is amethod of formatting any android device ( tablet or mobile). by doing hard reset all the apps and files that are installed or created.
How do i hard reset a polaroid t7 internet tablet? - my, Cannot factory reset polaroid internet tablet. how to hard reset a polaroid tablet model # pmid705x? i`m locked out of my polaroid internet tablet model ptab7xc i. How to hard reset android phones & tablets, restore to, Under the personal data heading near the bottom, you'll see an option to perform a factory data reset. select this option. if you're running android 2.3 or above, you.Hard reset - mobile recovery website, Hard reset ' follow @hard_reset new.hardreset.eu site would you do a hard reset of your device to wipe the data and start over? if you are about to sell your.
[how to] perform a factory reset - acer android tablet forum, Do not perform this factory reset procedure if you have an unlocked tablet and/or a custom recovery!!!! the factory data reset is a standard feature in android devices.. S7 factory data reset - southern telecom, S7 factory data reset if you have set a p.word on your tablet and forgotten the p.word, follow the instructions below to reset the tablet.How to factory reset an android tablet - pc advisor, Factory reset android tablet,google, android, tablet comments. lordganzgee said: i cant go to setting optionshow to reset my google account or p.word in my tablet.
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
