Freezers Logo
A
Anonymous Posted on Oct 16, 2016
Why haier freezer is beeping - Haier Freezers
Victor Nwachukwu
Level 2:
Guru:
  • Expert 157 Answers
  • Posted on Oct 20, 2016
Victor Nwachukwu
Expert
Level 2:
Guru:
Answers
157
Questions
0
Helped
39505
Points
347
Either way if you had the doors opened a lot, it should like you probably have frost build up preventing proper air flow. You'd need to pull everything out of the freezer and remove the lower back panel inside the freezer. If there is frost build up, you'll need to use a hair dryer to thaw all the frost out. The unit will continue to beep until the set temperature (0 and 38) are reached so that could take a while even after thawing out all the frost build up.
If removing panels sounds like more than you can handle, you can always unplug the unit for 24 hours and leave the doors open to allow the unit to defrost on it's own.
1helpful
Where is controller knob on freezer
Brenda, haier freezer control quite often front lower right corner, some may be behind freezer by compressor, check the links to see if you can find your model and manual. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://image.haier.com/manual/southeastasia/haier/freezer/chestfreezer/201203/P020120309357074931017.pdf
Haier Freezer manuals
Haier Freezer controls Google Search
Haier hnse05vs circuit
1-877-337-3639 This is Haier Customer Service number in US
1helpful
Why can't a Haier chest freezer be put in garage?
The only problem that you might have is with the coils and the flux capacitor. If you clean the coils, it should be fine.
2answers
Lost manual and need to defrost
This is likely a manual defrost freezer, which means you have to remove the food, unplug the unit, and let the ice melt on its own. Do not, and i repeat, DO NOT poke the ice away from the walls. I guarantee if you poke the ice away from the wall, you'll poke a hole in the wall, and force yourself to buy a new freezer.
SLOWER IS SAFER. put some boiling water, in the pot, inside the freezer, or use a hair dryer.
Haier freezer chest not cooling. Green light is
Do not put a towel on your freezer or anything that could prevent a good seal from top of freezer.
jim
Top Haier Freezers Experts
NOEL
NOEL
Rob Hill
Rob Hill
Are you a Haier Freezer Expert? Answer questions, earn points and help others
