SOURCE: I purchased an old Hamilton mantel clock that did
This clock has a floating balance escapement.
Hold the balance snuggly with 2 figures. Take a small screw driver and push one of the 4 legs above and attached to the disk to the "+" direction. Move it about 1/4 turn. Set the correct time and check again the next day. If the clock is still slow, move it again and set the hands. Do this until the clock is accurate.
Disclaimer: If this movement was made in the 1970 or early 1980's (The date is a 2 digit # above the movement model number). Those years the clock manufac. (Hermle) did not do well in quality materials. The may need an overhaul or movement replacement. I can provide more information if needed.
SOURCE: our swiss railway wall clock runs very slow.
If it is within the warranty period (usually a year), then you should return it to your supplier, with an explanation of the problem.
They should replace it free of charge.
SOURCE: seth thomas autoset wall clock not functioning.
I wish I had a solution... I'm in the exact same situation. I put in new batteries, and all I get is a faint reading of gibberish from the LCD screen, and that's it. I've tried following the instructions, but I can't set the time in the LCD clock, since it's unreadable, and almost completely gone. Seththomas.com has a web page indicating that "they will be back with info", but no support or FAQ pages. Disappointing... I have three of these clocks, and they are all behaving the same way.
SOURCE: We now have two wall clocks that have stopped.
Hello Battery - The La Crosse Technology clock must have a fresh battery to receive and process the time signal. Location - Try a different location, ideally near a window. It should be at least six feet from computers, TVs, air conditioners, other Radio- Controlled clocks and other electrical appliances that cause interference. Weather - Electrical storms between you and Colorado during the night will interfere with the WWVB signal. Although we cannot control the weather we can help you predict it (see www.lacrossetechnology.com). Daylight Savings Time The National Institute of Standards and Technology and WWVB encode a special DST "bit" in the WWVB transmission for DST. Your La Crosse Technology clock will read this information and automatically advance the hands one hour in the spring and eleven hours in the fall. Arizona and Indiana If you live in an area that does not recognize DST you must press the (unmarked) DST button for one second to deactivate your clock's DST La Crosse Technology, Ltd 2809 Losey Blvd. S. La Crosse, WI 54601 Phone: 608.782.1610
Check its battery contacts for any rust or dust. Anyway clean it well and put the pattery, and check whether it is working or not.
program. To reactivate the DST program simply press the DST button again for one second.
If you cant rectify the probelem, contact
Fax: 608.796.1020
or enter their website at
The device is a repairable one. OK.
SOURCE: Second hand has stopped working.
Hello To set up your clock simply install one fresh AA, LR6 ALKALINE battery. Due to the nature of long wave radio signals it is normally not possible to receive a signal during the day so it is best to install the battery late in the evening. Select your time zone by pressing one of the four time zone buttons PT-Pacific Time, MT-Mountain Time, CT-Central Time, ET-Eastern Time. The time zone buttons may be pressed any time after installing the batteries. If multiple buttons are pressed the clock will set to the time zone selected last. If no time zone is selected the clock will default to Pacific Time. Another time zone can be selected during or after the clock has set itself. Your clock can only set itself to one of the four time zones stated above. For time zones outside of PT, MT, CT or ET you must manually set the time using the Manual Time set button on the back of the movement. hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
Just setup the clock once again by replacing the battery and check. If this also does not help you, the the press fitting of the second is loose. you have to open it to make it pressed firm.
When the battery is installed the second hand will advance eight seconds (two seconds per step x four steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each
Select a location to place your radio controlled clock where it will be at least six feet away from a TV, computer, air conditioner or other household electrical appliances. The optimal location is near a window. Windows facing Colorado providing the best signal. The WWVB time signal will easily penetrate Masonry and wood framed buildings. WWVB will penetrate almost every residential building and most steel buildings if they have adequate windows. It is not possible, however, for WWVB to penetrate most indoor shopping malls and rooms in the center of large office buildings that do not have windows. In buildings that WWVB cannot penetrate you may set the time using the manual time set button. When the clock is exposed to the WWVB signal it will automatically set the hands to the exact time.
OK.
