I have a mitsubishi 1080 series wt-42311 model i power it on and led light turns off after 2 seconds, I held i=menue and input butons simeltaniously for 5 seconds and i got the blink blink blink blink blink blink blink blink blink blink code does anybody know what the problem would be?
Have you acessed the power indicator error code by pressing in the menu and input buttons on the front of the set both in together and hold in for 5 seconds? The led will blink a series of blinks to indicate a 2 digit code which will repeat several times. Let me know what the blink seqience is.
If model number is WT-42311 do the self check the set has.
When power light comes on and then goes off, on front of set press both the Menu and Input (device) buttons at the same time and hold for at least 5 seconds and then release both buttons.
Power light will blink a two digit error code like: 2 blinks, 2 blinks, a pause and the repeat the code several times.
Let me know what the error code is and I will tell you what it means.
If this has helped you, rate this solution as very helpful as I do this here for free.
2,2 IS short protection and 95% chance it means one of the two pico fuses that protect the convergence IC chips are bad.
This model uses two of the chips: STK-392-110 and you would have to pull the light box out to replace them safely (total parts cost will be under 30 dollars).
It involves getting at the chips and the fuses and replacing them: how much skill do you have?
On the front of the set press and hold BOTH Menu and Input (device) for at least 5 seconds and then release both buttons.
The power light should blink a two digit error code like: 2 blinks, a pause and 2, blinks. It will repeat the error code at least 5 times. To get it to repeat you have to unplug the set and plug it back in and try to turn it on again.
Let me know what error code you find and I will tell you what it means.
do the self check this model has and let me know what you find:
when it shuts off press ON THE FRONT OF THE TV both the menu and input (or device) buttons at the same time for at least five seconds and release both buttons.
The power light will blink a two digit error code.
for example---2 blinks, a pause and 2 blinks (this is the most common error code)
Let me know what code you find and I will tell you what it means and what can be done.
If this helped you rate this solution as I do this here for free.
STKs,one of them controls startup if bad TV will not come on.STKs are big black ICs will have part# on them. call Mats for parts you have 2 replace both. 1-800-628-1118
