SOURCE: whirlpool washer duet
F/06
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
SOURCE: f06 error code on Whirlpool duet washer
I have the whirlpool Duet 9150 with the same issue. I removed, reseated and reconnected every connector at least 4 times with the same random result of F06 to the point where it no longer finished the load. I then removed the motor control board again and sprayed it down with electronic cleaner along with all connections by disconnecting them , spraying them down and then reconnect and connected a few times to ensure good contact. I then tried again and the F -06 code came back. I then ordered the board for $ 150 online . When the new board arrived 4 days later, my wife tried the washer one more time and it worked. I have performed over 2 dozen loads . The board was never replaced. It appeared that spraying the board and connectors worked.
SOURCE: Whirlpool duet washer F21 error code. Just bought
"F21" is a Long Drain error. The following link explains how to torubleshoot:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
What this usually means is that you have something clogged in the drain pump and it needs to be cleaned out. In the majority of the cases, this corrects the problem. However, if you JUST purchased this washer, and it is brand new (not used), I would recommend you use your manufacturer warranty (good for the 1st year in most cases) to avoid the risk of voiding it. The conditions of some warranties, prohibit the consumer from opening the appliance and attempting any repairs. Read the find print just to be sure.
If you have any questions, please let me know. I hope this helps you.
SOURCE: i get an f06 and
F6
code is an issue with the motor drive tachometer.
Most often this is caused
by poor connections at the machine control or motor controller. Locate
the main machine control by removing the top panel and the motor control
by removing the rear panel. Remove each connector, one at time, and
reinstall. If this does not work, you likely have a faulty control.
E1
means that the thermistor is open and needs to be replaced.
The connections can be loose but the most likely cause of an E1 error is
a bad thermistor.
If you're comfortable and confident in your
do-it-yourself skills and have access to a volt/ohm meter you can check
and replace this part yourself.
For replacement parts - head on
over to SearsPartsDirect.com - PartSelect.com - or RepairClinic.com and
enter in your full model number for a full parts listing.
Hope helps.
SOURCE: Whirlpool duet washer-error F06 and E02
Unfortunately F06 E02 is a very bad error. It means you have an interface communication error. That means that the main control board isn't communicating with the front interface control board. You can pull the washer out and remove the 3 screws coming in from the back of the top panel. Next, the top panel will pull straight back, up, and off. Now check all the wire connections between the two control board and make sure they are all secure. If everything looks good, then the interface control board will need to be ordered and replaced.
Here is a link to the part.
