No matter how much ive tried the lettering is very small,
Depends on your machine, but remember if your machine has a 5mm needleplate opening, that limits the size of the lettering you will be able to produce. Unfortunately, to get larger output, you would need to upgrade to an embroidery machine or do the lettering manually with a satin stitch. You can, after practicing, do monogramming free hand with your machine and a satin stitch. However, remember, if the stitch width is limited, even satin stitch will still be limited by that stitch width.
How to Monogram with Basic Sewing Machine (be sure to use a stabilizer behind the fabric. Layer the fabric, then stabilizer, and put in an upside-down embroidery hoop--that way the fabric will be on the top and everything will be flat against the machine's sewing surface. )
How To Do Free Hand Machine Embroidery
(in this video, she puts the stabilizer on the top of the fabric, but it is wash-away stabilizer. If using a tear-away or permanent stabilizer, be sure to put it under the fabric.)
Sewing Perfect Satin Stitch Wildly Wonderful Wearables Patterns Notions...
Machine Appliqu Basics 5 Stitching irregular shapes using satin stitch...
How to Use Satin Stitch Foot
