You need to program the new board. Programming Mode:
NOTE: The Program Code is located on the Serial Plate on this unit after the word Code.
1. Press and hold the Door Alarm Keypad .
2. Press and hold Freezer Temperature Down Keypad .
3. Release the Door Alarm Keypad and wait 3 seconds.
4. The control will display PE to indicate the programming mode.
5. Entry is confirmed by pressing the Freezer Temperature Down Keypad once more.
6. The control will display the current Program CODE. This value should be validated with the
Program CODE printed on the unit serial plate.
NOTE: If the Program CODE is correct, the Programming Mode is exited by pressing Door Alarm Keypad for 3 seconds.
7. Press the Refrigerator Temperature Up Keypad or Refrigerator Down Keypad to change the digit value with each key press.
8. The decimal point indicates the selected digit. Press the Freezer Temperature Up Keypad to select the next digit.
9. Once the desired Program CODE is entered, press and hold the Freezer Temperature Down Keypad until the Program CODE begins flashing indicating it has been saved.
NOTE: If you attempt to enter an invalid Program CODE the control will not save the new code, but will beep. (The unit will NOT run with a Program CODE of 0000).Once the Program CODE has been saved the Programming Mode is exited by pressing any key. If the new code is incorrect this process should be repeated.
The Programming mode can be exited at any time
SOURCE: Maytag digital panel click on, then off. Refrigerator is warm.
The fault may have three places that it could come from. The Digital Logic Panel itself the motherboard or the low voltage transformer. If you like I will help you, Let me know, Thanks, Sea Breeze
SOURCE: After installing a new mother
It's board are already programmed so check it's wiring for open, look for deformed component it may cause it not buttons to work. Also do not overlook the possibility of a factory defect control board sometimes it do happened. Be sure that you installed it correctly the same as the old one. Look for loose connection.
Thanks for asking. Good luck.
SOURCE: Maytag French Door Refrigerator panel is flashing and ice door keeps opening and closing
You have a maytag refrigerator and it has a bad main pcb (on the back of
the unit). The noise only happens when the compressor is running.
Put a rag in the ice chute to keep the door from making so
much racket. If you post your model number I will get you a part
number.
If you want to verify what I am saying you can unplug
the unit and remove the cover panel from the main pcb on the back of the
fridge and one or two of the capacitors will be rounded on the top, not
flat like the others. If that is the case then that is the problem.
