Hi visit Onlinegsmunlock.com to unlock your Sony Ericsson MT11i mobile from network lock .Here they ask you the network name to which your mobile is locked and the IMEI number of your mobile .Then at last they deliver you code to unlock your mobile.
Hi, problem can be solved. When a phone battery indicates 99 % of battery life and runs down so quickly, it is caused by damaged battery. When a battery cell is damaged, it will display charging full but itwill empty. You will need to replace the battery for a better battery performance.
When a new battery is been purchase, make sure it is charge it is charge up to 4 to 5 hours before use.
Hi, Sony ericsson w850 is an amazing phone. you just said, it was dead. Sony ericsson phones mostly have battery problems. so check your battery. change it with your friend's one (if he have sony ericsson mobile). If it worked, buy yourself a new battery.
I like to give you a trick. I saw some sony ericsson phones work without a battery inside when you connect the charger and charge up without a battery. Try this trick too. If it works, buy a new battery.
If your battery is ok, then it might be an IC problem or software problem which can be repaired only by service men for a nominal charge..
hi sir... dont change ur batteries or go for new one... Its becuase the battery pin available in ur mobile device has got damaged... so its unable to store charges for a longer duration...Better give ur mobile for service and they will replace u with new pins.. dont waste in getting new batteries..
Hello jdavi187 and LesB , This problem sounds like a hardware fault to me ,on the mobiles motherboard . The tiny surface mounted capacitors on the board that control the voltage and current from the battery get shorted out or simply stop working properly or if you drop the mobile it can create a dry solder joint on these components, sounds like you will have to take the mobile to a professional mobile technician,trying to replace tiny surface mount capacitors or resistors is nearly impossible without the correct tools and equipment.
If you can try another fully charged battery, in your phone and it works then it might be a dodgy battery problem. leave the phone off to charge the battery for 10 hours and see if its better.
