Cycling Logo
Sara Christensen Posted on Oct 12, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi I recently bought a used roadmaster mt sport sx bike and the rear gear that's attached to the wheel is moves like in circles... is that supposed to happen... if not how can I fix it?
Donald Ayers-Marsh
Level 3:
  • Roadmaster Master 1,389 Answers
  • Posted on Oct 13, 2016
Donald Ayers-Marsh
Roadmaster Master
Level 3:
Answers
1389
Questions
0
Helped
559243
Points
6679
Lots of things on a bike move in circles. If you mean it moves when you pedal but does not "catch," so the bike does not move forward then that is a problem with the rear gear cluster. You need to have a mechanic look at it. If that's not what you mean you need to get help in providing a more clear explanation.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
1 Related Answer
Anonymous
  • 190 Answers
  • Posted on May 03, 2011
SOURCE: My daughters mt sport sx
phililisa03-
This problem is caused by improperly adjusted derailers/shifters, the mechanism that move the chain from one gear to the next. It is not uncommon for the derailers to be out of adjustment after sitting unused through the winter. Over time the cables that run between the shifters and the derailers stretch just a bit and the derailers no longer work as well without a little tuning up. Unfortunately, for the novice, adjusting the derailers is frustrating at best. The effort and patience it requires is nothing to take lightly. If you're game for giving it a try, there are a number of websites out there that will provide extensive guidance on the process - just "google" how to adjust bike derailers" and you will find plenty of options. My local bike shop will make adjustments like this for a small set price, around $20 or so - you may have a shop nearby that will do the same.
Hope this helps.
Regards,
DIYpro
Do you have Roadmaster bike manuals
The only thing I can recommend is go to Walmart, ask them. Or look for a Roadmaster on their shelves, look for a website in the booklet hanging on thebike
Replace rear tire
Remove rear wheel from bike. Deflate tube by removing valve stem. Tire should remove easily by pulling rim of tire over the rim. IF difficult, take to local bike shop for assistance
2answers
I have a R4447wmlt i need a rear rim with spokes
you will find it on e-bay or from the manufacturer spares
1helpful
My bike's suddenly not moving my bike's suddenly not moving backward..... its a Schwinn Suburban Sport 26" for women... bought it an hour ..
It's not supposed to move backward. Walk it forward and rotate the pedal FORWARD to get the chain and all aligned onto a gear. Then evaluate what is wrong.
I need a guide on the gears on a Mt. Fury Roadmaster 15-speed bike.I DON'TNOW WHAT THE DIFFERENT GEAR READING MEN
Eventually you will ween off those indicators but lower numbers mean lower (easier) gears.
Use a Search Engine to find "how to shift gears on a bicycle" and you will find a multitude of videos demonstrating the craft.
Jun 29, 2011 • Cycling
1helpful
My daughters mt sport sx roadmaster bike keeps changing gears and making a clicking sound. What causes this?
phililisa03-
Hope this helps.
Regards,
DIYpro
Hi, I'm owner of 2002 Moto Guzzi V11 Sport Naked My mechanic dismantle the bike for sandblasting the engine due to famous problems with this model paint. He don't note the adjustment of rear wheel arm...
Hi there.
Often the adjustment of the rear swing-arm, particularly for bikes like yours, requires a special tool, or knowledge of the correct adjustment angle.
A Moto Guzzi dealer would be the best person to speak to regarding this. They may even be able to tell you over the phone what the angle and distance is, and possibly how to adjust it.
Otherwise, taking the bike to them might be the best option.
Can I raise up the handle bars on my 26" Ladies'
No, but a bike shop can assist you in selecting and fitting a stem with a higher rise.
I just bought an InStep® Joyrider Bicycle Trailer and the photo's are not very good. When attached is the bike trailer hitch supposed to attach perpedicular to the bike and the spring bends to 90 deg....
The hitch part that fastens to your bike rear axle has 3 pieces, a dimpled washer which goes on first then the hitch plate and a pin that holds the trailer to the hitch. Take off the axle nut (15 mm wrench) install the dimpled washer it goes on with the 90 deg tang facing the bike wheel and in the channel so it can't rotate. Then put the hitch plate on, mine faced down for the correct height, line up the dimpled washer with the bumps on the hitch plate to locate it properly. reinstall the wheel nut and be sure to align the wheel so it runs straight and true (I oopsed on this the first time) then attach the trailer, it is a 90 deg hook-up then you simply put the the pin in and you are good to go. The unique hook-up makes it so smooth and dampened that you don't even know it's behind you. We really love ours!
4helpful
3answers
Schwinn S40 DSX part name
Forget new guide wheels. A new rear derailer is the real fix. You will need to order a new one by the number of gears on the rear gear cluster. How the derailer is mounted, Which way it moves when by the spring direction etc... By the way, get a higher quality one than the one you have got. If you go megawheel on the lower guide wheel; which I recommend, you might need a couple more segments in your chain. Yes, you need a new chain. If you wore out a part on you derailer, your chain is getting old. I recently bought a new rear derailure for my wife's bike for 29 bucks at a much better quality than the old one. It does not have problems of getting between gears, clicking etc... like the old one did new.
Top Roadmaster Cycling Experts
Arnie Burke
Arnie Burke
Kardoc
Tony Parsons
Tony Parsons
Are you a Roadmaster Cycling Expert? Answer questions, earn points and help others
