SOURCE: Porter Cable C2002 150 Psi 6 Gal Compressor. The
YOU WILL NEVER GET 150 UNLESS YOU PUT A DIGITAL GAUGE.
SOURCE: i am missing half the
Pig tails are available thru Lowes in various wire gauges and lengths. Remove cover to pressure switch and notice wiring and replace with new cord (9 to 12 feet will work great). If your pressure switch is inside the cover and you do not want to bother with complicated procedure; just install a male plug on short remaining cord and just buy a 12 foot 14 guage cord. Good holidays
SOURCE: porter cable 135 psi 6 Gal model no. d27420
These units are disposable so if the motor is gone, it is garbage. I would try a power tool repair center to see if they have any used motors to repair your unit. Save the tank and use it as a slave unit for a new compressor. This way you will have more volume and the compressor will run less overall making the new unit last longer. If you burnt the motor out on this one, consider buying a larger unit the next time. Hope this helps.
