Bike stalls every time I come to a stop. Even when completely warmed up
SOURCE: Bike stalls at traffic stops unless I keep giving it gas
check exhaust gasket for leak, check spark plug, air filter,valve tappet clearance adjustment, and intake boot for leak,if ok do compression test142-203 psi. if ok carburator may need cleaning.
SOURCE: IVE GOT A ktm lc4
haw is your idiol speed is it low . it sounds like the starer cluch is sliping you need to remove it and check it out for were
SOURCE: 92 nissan sentra Stalls while idling
I had this kind of problem on my car a couple of times. It can either be the idle control valve or overheating. you can clean the idle control valve or replace it. the one for my car was like $140 at the dealership.
