The Times ROYAL TC100 TimeMaster Time Clock Logo
alan goddard Posted on Oct 11, 2016
How to set the time clock on bush video 6 head vhs
No picture but has sound in VHS, Both work in DVD play
The main cause of this is a dirty video head. You can get a head cleaning tape that will clean the head. Or you can do it manually. But you have to take off the top cover and spray the video head with Servisol Video 40. Allow it to dry and test the machine. If it doesn't do it the first time or the picture is breaking up, clean again.
After my mother passed away, I inherited an Emerson VHS/VCR Model VCR4010. It works just fine, but I can not figure out how to set the clock. I do not have a remote control for this machine. Can you...
Set the date and time by pressing "Menu" and selecting "Clock Set." Use the "Play" and "Stop" buttons to set each facet, and press "F.Fwd" to move on to the next. When finished, press "F.Fwd" or "C.Reset/Exit" to save the settings.
I HAVE A PANASONIC DVD,VHS RECORDER MODEL #DMR-EZ48V.WHEN TRANSFER A VHS CASSETTE TO A DVD THE THUMNAILS ON THE DVD HAVE THE DATE OF 1/1/2000. HOW CAN I PUT THE ACTUAL DATE OF THE RECORDINGS ON EACH OF THE...
Try setting the clock on the remote press [FUNCTIONS] go to SETUP menu - locate the CLOCK option (it should be under 'OTHERS' in the setup) and set the current time, press [ENTER/OK] to store if necessary, then press [RETURN] to exit the setup. Once clock is set correctly, future DVD thumbnails will show the actual date/time of recording in this (and similar) model combo units. If auto clock setting is not possible, set it manually as above.
I assume in spite of the wrong date/time, your DVD recordings have been successful. Incorrect clock and date setting usually only affects timer recording for VHS.
If you have lost or misplaced your original owner's manual, you can download a free pdf version (for Region 1 model) from:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ48VK
or, if you live outside USA, download the 'Australia/NZ' pdf version of the manual (for Region 4 model) from:
http://www.panasonic.com.au/Products/DVD+and+Blu-ray/DVD+-+Players+and+Recorders/DMR-EZ48V/Downloads
either one of these will provide you a full copy of the original user guide/setup including clock.
All free. Hope these suggestions help.
Sony SLV-D100 DVD/VCR unit won't record on a VHS tape.
Check the tab on the VHS tape be sure it is there. If not place a [piece of transparent tape on it to simulate the tab and try again.
JVC DR-MV1S VHS Tracking
No manual tracking or if there is it wont help.either heads are worn or possibly dirty.if u open it .i assume u have.the silver drum has little notches around it.2 ,4,or 6 these are the heads.get some alchol or aftershave will do.take a peice of card playing card size is ok .must be plain not printed.apply some aftershave alchol to card not dripping ,hold card against the dum then with other hand turn the drum back and forwad not moving the card,u may damage heads.when u check card it should show some dirt reassemble and try.otherwise its museum time show the grandkids see if they know what a tape is
Got no instructions
1-The TV needs to be on channel 3.
2-On VCR remote set VHS/TV switch to VHS. (click it a couple of times until VCR channel shows on screen)
Unable to set up clock om my vhs panasonic, please help
You have to set the time and date on the remote controle, then send it by IR to the unit !
I dont have the exacte way to follow here, but you have an idee to to it !
Can't read the date/time
There may be a simple explanation. Here are two possible reasons this is happening: * You may have disconnected the power source before turning off the power to your camcorder. If you remove the power source from the camcorder while the power is on, all settings and selections will be erased. Make sure to turn the camcorder's power off before disconnecting the power source. * This is particularly an issue for some early VHS-C camcorders – those with model numbers beginning with a "6" and ending with a "2" or "3" (i.e. CC6xx2 … CC6xx3). These camcorders have a consumer-replaceable clock battery that may be exhausted. If that battery runs dead or is removed and the main battery or AC is not connected, the camcorder will lose all its Date and Time settings. * In some models, the date and time display is designed to do this. When you turn on many VHS-C and digital camcorders, the Auto Date mode will display the time and date. When recording begins, the date is recorded on the tape for 5 seconds and then disappears. In the viewfinder, the date will then be replaced with the words AUTO DATE but they will not be recorded. They remain in your viewfinder so that you know this feature is on. On full-size or VHS camcorders, the Auto Date feature is very similar. When you first turn on the camcorder, the date along with the word AUTO and a Clock icon appear in the viewfinder. When recording begins, the date is automatically recorded for 10 seconds and then disappears. In the viewfinder, the Clock icon and the word AUTO remain but they will not be recorded. They remain so that you are aware that this feature is on. When using the Auto Date feature, be aware that the time is only recorded when you first turn on the camcorder and begin a recording session. It does not record each time you press the record button. There are a number of time and date display and recording options. Since these vary by model number, please refer to your owner’s manual for more details.
Top The Times Office Equipment & Supplies Experts
k24674
Are you a The Times Office Equipment and Supply Expert? Answer questions, earn points and help others
