Your goal is to install this switch in the line that is providing power to light or will be. Most switches should have two screws, and should be installed in the line that is hot ( black wire or verify with meter)! With power removed to the line you would cut the line stripping back some insulation and now have two black wires that are stripped. One wire (copper ) installs on each screw. Remember to attach wires so when you make the screw tight you will wind wire clockwise.
The "On" should be up.
return power, turn on switch
