My sub main fused isolator switch seems to be wired with Live and Neutral reversed when I check the outlet sockets with a neon tester it indicates all correct and if I put the meter tails live to live and neutral to neutral on the switch the neon indicator indicates L and N reversed.
SOURCE: Understanding Outlet Circuit Test Results
open ground=ground wire (green) is not connected to the circuit box ground or to the earth ground.
(there should have steel rod place in the ground by the local electric company, and gtound wire is connected to that rod).
Open Neutral= same as open ground. unless you are testing 240V, which have 2 hot (110v) and a neutral (0V).
Open Hot= open 110v line (black)
hot/ground reversed= if you understand the above, then this sould be self explaintory.
same a hot/neu. reverse.
if you don't understand how electric wiring works, My suggestion is to stay out.
SOURCE: I have 4 x 25mm wire armour cable going to a
you have 240 v going to this 2 hots,1 neutral and a ground red and black is hot, white is nuetral ,green is ground
SOURCE: am fitting new ceiling lights have 1 live 1
the 2 live wires are 1 for lights,1 for fan,keep them separate if you want control from 2 wall operated switches,if you only want control from the switches on the fan you can tie these together,as for the2 neutral wires they can be tied together at the fan box,and the 1 earth wire goes to the metallic surface ground screw on the unit
