Phone is stuck on silent mode
SOURCE: how to take silent mode
To turn off silent mode, press the "#" and hold down until it changes. :)
SOURCE: Hoe do I get my Uniden DECT 6.0 Cordless Telephone Expansion Handset with Caller ID off silent mode?
What's the answer???????????
SOURCE: how do you turn off silent mode on Uniden DECT 6.0
In standby mode pressing and holding # brings up the "Silent Mode" special feature .. unfortunately the only options are to set the time for the device to be in silent mode and no way to turn if off. The solution is supposedly to press the # key again and hold it down, but this does not work either. The only way I can manually return to not be in "Silent Mode" is to reset the base unit!!
SOURCE: how do i take silent mode off an uniden dect 6.o cordless phone
Hold the "Silent Button" down for a while. It is shared with the # key.
SOURCE: How do I turn off the silent mode on a Uniden 6.0 dect phone, so it will ring?
For the Uniden model D1680 & similar...
You ENTER "Silent Mode" by pressing and
holding the [ # ] key on the handset for a few
seconds until the display reads "Please Wait".
It will (chirp) and display "Silent Mode ON".
You can EXIT "Silent Mode" by pressing and
It will (chirp) and display "Handset #".
Another easy way to end "Silent Mode" is to go
to the BASE and press the [ANS ON/OFF]
button to turn off the answering machine system.
(Push the [ans] button, do not unplug the power)
"Silent Mode" will clear a moment later while the
control voice tells you "Answering System is OFF"
Now you can again turn on the answering machine
system as desired.
Hi lisa bowling, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
What model Uniden DECT 6.0 phone?
