When you say it does nothing do you mean the motor wont come on or the motor comes on and it wont build pressure? if the motor comes on, there are several possibilities:
1. The unloader valve is stuck open
2. The valves in the head are bad
3. The flywheel is loose
If the motor wont come on, the pressure switch is bad (which holds the unloader valve open)
http://www.mastertoolrepair.com/air-compressor-parts-vt6362-p-60727.html
the motor does nothing wont turn on at all
You can get that part at lowes, also takes pictures as you go so you can see
thanks i give it a try
