I changed something by accessing ip adress(i typed my ip address somewhere in the menu) now i cannot access ip address
HI! you can access the ip address of your router by connecting it directly to your computer.. if you are using a windows xp operating system. use your mouse and click on start and select run, from there it will show a box and type in on the box cmd and it will show you a dos prompt and from there just type ipconfig /all and it will show your ip address..
Here are the instructions to get your ip address.
connect you computer to internet
start --> run... --> cmd --> ipconfig
above instructions will show you your ip address
If this sounds too complicated you can find your ip here.
click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all of your internet connection details
or type in your default gateway adress into your internet search should read something like 10.0.0.138 to get an inertnet connection
hope this helps you
Please tell me which Operating system are u using on ur computer???? Thanx Archie
