Question about SanDisk Sansa e260 MP3 Player
My sansa e260 needs repair, where do I go?
Battery will not charge,tried new battery,twice. Now what?
SOURCE:
mixmaster
  • 626 Answers
SOURCE: Sansa E260 Charging Problem
The battery may have become disconnected from the contacts, therefore it will not charge the battery but lights up when connected to the PC. Remove the 4 screws on the back, remove and re-seat the battery. Charge the device for a few hours. Best of Luck. p.s.- you can add to this question if this didnt help.
Posted on Oct 08, 2007
mixmaster
  • 626 Answers
SOURCE: "Battery Is Too Low System Shutdown"
The battery has come loose from the contacts on the inside.
Remove the back (4 screws), remove the battery and put it back in securely.
Then charge it for a couple hours.
Best of Luck.
Posted on Nov 14, 2007
  • 4 Answers
SOURCE: my sansa e260 wont turn on or charge
I had the same problem. Place the device into hold and press the menu and mic buttons at the same time. The first time I tried it, I had no response and then I pressed the same buttons again and my e260 came back to life.
After getting my e260 to come on, I updated the firmware and everything has been working.
Posted on Jan 31, 2008
  • 5 Answers
SOURCE: how do i delete pics from my sandisc sansa e260.
The MUSIC folder is a "hidden" folder when in MSC mode.
To view it (assuming you're using Windows XP) go to:
My Computer>Tools>Folder Options>View Tab.
Scroll down till you see Hidden Files and Folders
and click on Show Hidden Files and Folders, and then OK.
You should then be able to see all the folders on your Sansa. The "hidden" folders will appear slghtly lighter in color. This is where you can delete click on folder then go toleft of screen to "delete this folder" (or open folder and click individual song" then go to left of screen
Posted on May 26, 2008
SOURCE: Sansa e260 battery trouble
please tell i want a new battry of sanae250. Where i can gt tell me.
my email address is heena_gogri@yahoo.com
Posted on Jun 08, 2009
SanDisk Sansa e260 (4 GB) MP3 Player MP3 and Digital Media i have a e260 sansa mp3. when i plug it into my Answer i have a e260 sansa mp3. when i plug it into my computer it wont charge what should i do
There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Jan 30, 2010 | SanDisk Sansa e260 MP3 Player
Can't turn on sansa player
try pushing the power botton on for ten seconds and then try or hook it back up to you computer for about 30 min and try again .... your battery might not be holding a charge (you might need a new battery)
Dec 31, 2009 | SanDisk Sansa e260 MP3 Player
Hi! My Sansa e260 won't turn on. It charges
try upgrading the firmware...if that doesnt help u'll need to replace the battery here's how to update firmware- http://kb.sandisk.com/app/answers/detail/a_id/306
Aug 14, 2009 | SanDisk Sansa e260 MP3 Player
Not holding a charge
You might need a new USB cable. the one you have could have a short thats keeping it from charging.
Jan 21, 2009 | SanDisk Sansa e260 MP3 Player
Charger
Your USB port must be repaired. In the meantime, hopefully, your computer has another USB port that you can use. Battery is a replaceable lithium ion rechargeable battery. There are battery chargers that you can connect to wall outlets - the type that plug into the computer would probably require that you plug it into the USB port, which you said is broken - so that's a no-go. There are multiple vendors for battery chargers - one possibility is http://www.greenbatteries.com/
-Tha Mp3 Doctor
Jun 02, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260 MP3 player
You Might Need a new battery or also try cleaning  the usb intreance of your sansa e260 with a Q-tip.
May 19, 2008 | SanDisk Sansa e260 MP3 Player
E260 4gb sansa not turning on
some may be due to low battery power or due to software problem...while charging stop once the charge gets full,...dont overcharge the battery,,,,,,the battery life gets reduced
Jan 03, 2008 | SanDisk Sansa e260 MP3 Player
You might want to buy a new battery. I belive you could probably get a new battery at walmart and best buy.
Oct 20, 2007 | SanDisk Sansa e260 MP3 Player
Oct 08, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
