SOURCE: automatic document feeder
you have to replace it if cleaning doesn't help. look for the seperation tire or pad if it picks up the paper from the top first then the sep is on the bottom and vice versa. Clean that on really good this is the one that seperates the paper and stops it from feeding more than one sheet.
SOURCE: Automatic Document Feeder
what part do you need exactly, ADF is a part of the whole unit of your printer/Scanner, usually there were few parts available in the market,sometimes they are not replaceable, or you can find a cannibalized parts, if you let me know which one is defective
SOURCE: paper jam in the automatic document feeder
I have a Laser Jet 3050..when I try to load a oaoer to copy or fax, paper does not move...just gears moving but paper is not being pick up...any solutions?
SOURCE: automatic document feeder not working
Open the adf and rotate the pick assembly till you hear a click and then take a coin and run it up and down against the separator pad and then see if the adf picks the paper or not.If this does not work try this *# 329 and scroll thru and select adf pick test if that fails its time for you to get the printer replaced or get an upgraded printer
SOURCE: Automatic document feeder will not feed. Tried
Check the sensor. (See here)
Take a look at solutions offered here.
Sorry I can't offer much more at the moment, the HP search engine is down for maintenance...
