Question about Pride Mobility Products Used Jazzy 1120/2000 Electric Wheelchair
Jazzy 1120 goes in circles to the left. started only occasionally now always. sometimes turning pilot controller off/on corrects problem. motor brushes ok
5 Suggested Answers
SOURCE:
kmhabdullah
SOURCE: Wiring Diagram Pride Jazzy 1120
mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There are two levers just under the seat at the front. Pull the forward and to right to lock position, which will release the gear so that the wheelchair can be move about without any electric power. Bear in mind though that releases the gear, still too heavy to push as normal wheelchair. Give a go, to find out for yourself.
Posted on Aug 28, 2009
  • 103 Answers
SOURCE: 2 lights blinking on control stick. and chair
sounds like you need a new motor. 2 flashes indicates left motor.
Posted on Nov 06, 2009
  • 7 Answers
SOURCE: The joystick is not sensitive enough, there is a
The Jazzy wheelchairs have programmable controller. This includes the length of the pause before moving, speed, acceleration speed and deacceleration speed. You usually need a programmer to change the programming. You supplier should have one. For your nearest supplier have a look at the pridemobility website: www.pridemobility.com
Posted on Jun 01, 2010
  • 692 Answers
SOURCE: my hand controler on my
GAdams You need to count the number of flashes. The number of flashes will give you the flash code or error code. IE: 3 flashes pause 3 flashes pause etc. = left motor short If you have your owners manual it should list the flash codes and what they mean for your chair. If not you can contact Pride Mobility @ 1-800-800-8586 and ask for Tech Support. If medicare paid for your chair the they will pay most of the repair cost. Contact the provider where you got your chair to see if they can repair it or refer you to a service Company that can. Hope this helps
Posted on Oct 08, 2010
Jazzy 1120
"Cuts out" is not enough info. Check all connections for tightness, full battery and light codes.
Apr 29, 2013 | Pride Mobility Products Used Jazzy...
Jazzy 1120 changing controller type?
The 1120 usually comes with either of 3 different controllers: Pilot, Remote Plus or Europa. They function similarly but the setups are a bit different.
Apr 02, 2013 | Pride Mobility Products Used Jazzy...
My whell chair moves too slow going forward
The 1120 can come either of 3 controllers. Find the speed control and adjust it to your desired speed. If you have the Pilot Controller the speed dial knob is at the rear of the controller. Be sure to fully charge the batteries after each use and check all connections for tightness.
Mar 23, 2013 | Pride Mobility Products Used Jazzy...
My hand controler on my jazzy 1120 2000 keeps blink and I can not get the chair to move the batteries are good
Oct 05, 2010 | Pride Mobility Products Used Jazzy...
The joystick is not sensitive enough, there is a pause between the joystick movement and the motor response. Jazzy 1120 how to adjust it?
Apr 21, 2010 | Pride Mobility Products Used Jazzy...
Jazzy wheelchair 1170....left side stops and sticks,.
Change out the motor brushing on the motor that is not working, or get a nail filer & rub it against the metal pins the back of the chair for a better connection
Nov 30, 2008 | Pride Mobility Products Jazzy 1170 XL Plus
Pride Mobility Products Used Jazzy 1120/2000 Electric Wheelchair Logo
87 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Will
Level 1 Expert
Marvin
Marvin
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
