Watches Logo
Arnold Olsen Posted on Oct 07, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Getting the stop watch to work or are the buttons just for show?
deton8 von Splosion
Level 3:
  • The Master 3,342 Answers
  • Posted on Oct 07, 2016
deton8 von Splosion
The Master
Level 3:
Answers
3342
Questions
6
Helped
928867
Points
54123
Typically no...
Not unless you got it out of a BUBBLE GUM MACHINE.
Those buttons are not for show...
Properly INITIALZED ... the buttons should allow you to check lapsed time... total time... a vast array of other "STUFF".
Even the cheesy knock offs have working chronometer...
chronograph functions...!!
How about you put down a few specifics... make model... and do a search on the internet.
You will likely find the owners manual... with all the trimmings!!
The you can do what we techies call RTFM...
Read the manual... It always helps!
How do I set the time on my gold watch that has three buttons
As your watch has 3 buttons I am assuming that it has the main dial and 2 sub dials maybee to show the date. The centre button should pull out (DO IT GENTLY) and either will stop or click ,you should then rotate it to set the time, when done push it back in to start the watch running.
The 2 outer buttons probably work by pushing them in a click at a time to set there respective dials.
Oct 02, 2017 • The Watches
1helpful
How do I use the buttons in this QHY watch?
Hopefully, this will help...
Lego Watches Manual Instruction:
There are 4 buttons on this lego watch case, Light button, Mode button, Stop button and Reset button, now I will show how to set the time easily!
1, Light Button: Press this button, the watch LCD light will display for 3-5 seconds;
2, How to use the stopwatches chronograph function?
Answer: When the lego watches in normal working condition, Press "Stop button" for 1 time, then the watch goes into the chronograph mode, then you can use "Stop button" and "Reset button" to operate this function.
3, How to set the alarm time?
Answer: When the lego watches in normal working condition, Press "Stop button" for 2 times, then the watch goes into the alarm mode, then you can use "Stop button" and "Reset button" to set the alarm time, also you can turn off or turn on the alarm function and chime on every hour function by the same operate.
4, How to set the right watch time, hour, minute, second, week, date, month, year?
Answer: When the lego watches in normal working condition, Press "Stop button" for 3 times, then the watch goes into the time setting mode, then you can use "Stop button" and "Reset button" to set the second, minute, hour, week, date, month and year.
This is all. So now please have a try to set your lego watches time!
Dec 06, 2014 • Watches
1helpful
2answers
How do I make the watch stop chiming on the hour?
It seems that most 4 button electronic watches have similar directions. There should be four buttons. Clockwise from top left is the Light button, followed by S2 (Stop), S1 (Reset) and finally on the lower left S3 (Mode). Who knows why they are numbered this way. To set hourly chime Hold down S1 and press S3. When all 7 day flags show the chime is on. When they are off the chime is off. To set the alarm hold down S1 and press S2. Alarm icon will display or go off. Release S1 button and display will return to normal time. Hope this works for your watch
2helpful
10 year old Seiko Kinetic (model5M62-0B00) blue face. Last week stopped and after some shaking started again but seconds moved in 2 sec intervals for a few hours. Went OK for a week and again last night...
After 10 years it will be likely that the Kinetic capacitor will need upgrading. Your watch is designed to tick in two second intervals to tell you the power is very low. The power button will work again when it has some power to show. Yorkshire Watches www,yorkshirewatches.co.uk can do the upgrade for you if your in the UK. Give them a ring.
9helpful
3answers
My G-Shock doesn't beep every hour, how do i get it to do that?
To make it beep every hour you must first put it on the alarm mode. Then, press the START-STOP button until a little bell shows up at the left. Hope it helps!
Polar F6, stopped counting calories and stopped showing heart rate. Buttons will not work and it reads Calorie? at the top
You will have to go to Polar for this problem. Sorry.<br /> <a href="http://www.polarusa.com/us-en/">http://www.polarusa.com/us-en/</a>
55helpful
2answers
Aw60447w digital watch. I cannot turn off the hourly beep. help
Hourly chime on/Off:
1.) Press and hold the lap/reset button (bottom right) to display alarm time
2.) While holding lap/reset button, press the mode button (bottom left)
3.) If the all the day of week indicators our lit, beep is on. If they are all off, beep is off.
Alarm On/Off:
A press of the lap/reset button (labeled) will show the alarm time, Unpress will show the time of day. Press again toshow the alarm time. Press and hold the lap/reset button will show the alarm time again, but it will hold there. While holding this lap/reset button, press the start/stop button (labeled). This will turn on (or off) the alarm (tiny indicator). Press this start/stop button repeatedly (while still holding the lap/reset button and you will see the indicator turning on and off with each press. Stop this button pressing with the indicator OFF, let up on the lap/reset button, and the time will return to the screen. The alarm will now be OFF.
Jan 26, 2010 • Swi Watches
Buttons on casio pro trek watch stopped working -time still shows
Sounds like the solar back up cell needs to be replaced. You can get it repaired for rather cheap less that $30(US). You can contact www.casiosalesandservice.com to have it serviced. 877.659.0761
5helpful
I have an Athletic Works watch and can not turn off the alarm.
the mode button controls the different functions of the watch.  time, alarm time, stopwatch, timeset, alarmset, in a repeating cycle.  Make sure you are on the time function (seconds ticking and changing every second, but not flashing twice per second.  This is the normal mode that shows the time.
Top The Watches Experts
vince
NOEL
NOEL
Paul Carew
Are you a The Watch Expert? Answer questions, earn points and help others
